Old 04-08-2003, 02:04 PM
harris10101 harris10101 is offline
Send a message via AIM to harris10101
soldering prob
im doin the dual cell mod on my zz, and i got a wire soldered to one of the batteries but i cant get it soldered to the back (flat side) of the other batter.
im using flux cored solder so i dont need flux do i, because that seems to be the problem, but i dont know why it isnt soldering
Old 04-08-2003, 02:09 PM
sessiz10's Avatar
sessiz10 sessiz10 is offline
Told ya.
If you have some sand paper try sanding the face a bit to rough it up. Not too much now just a few scratches and the solder should stick better.
____________________
Meh.
Old 04-08-2003, 04:17 PM
IHAD2HAVE's Avatar
IHAD2HAVE IHAD2HAVE is offline
I agree with the above fellow try just to take the shine off it.heast up your iron get it nice and hot.tin your iron( that means to get it hot and then add the solder to it so the iron is covered with solder) Tin your wire (same as above) once both are tinned and your batt is sanded add the iron to the battery and just as the solder is getting shinney/molten add your wire and it should stick fine
Old 04-08-2003, 04:24 PM
Zephyranthes's Avatar
Blitzer Sonic
Radioshack has soldering tape. Tape that conducts electricity.
Old 04-08-2003, 04:28 PM
ill try the sanding but if that doesnt work the tape it is, thanks guys
Old 04-08-2003, 04:30 PM
strider_mt2k
I haven't had any trouble soldering to batteries in the past, but you can try an old soldering onto aluminum trick:
Rough up the surface with sandpaper, and put just a TINY bit of motor oil on the metal prior to soldering. (it can be used motor oil)
If that doesn't work then you should start worrying about how many times you're cooking the battery trying to solder to it.
Soldering iron accident (serious) Char-g Ace Bit Char-G / MicroSizers 23 07-01-2003 12:45 PM
new soldering iron BabyKiller Bit Char-G / MicroSizers 29 05-24-2003 02:59 AM
I'm a Soldering Fool!!!! Buzzbait Bit Char-G Mods and Projects 5 05-01-2003 04:11 PM
ARGHHH! HELP with SOLDERING! syncronized Bit Char-G Mods and Projects 15 04-26-2003 01:33 PM
Soldering Iron nrmcj Bit Char-G / MicroSizers 17 02-13-2003 06:54 PM
