04-07-2003, 02:36 AM
Go
the pic explains all (mod is for if your cars rear axel keeps falling out and will not stay in). My firend thought of this.
________
IOLITE REVIEWS
________
HERBAL VAPORIZERS
________
Volcano vaporizer solid valve vs easy valve
04-07-2003, 03:35 AM
er..
I must say this: Nice pic!
But wouldnt the toofpick stop the axle from running well..like touching it and slowing it down..?
45 MHz Nissan Gloria Bit Char-g
Custom Tires (back)
Medium tires (front)
TOMY Bit Racer 2.6 Motor
04-07-2003, 04:17 AM
Chunk
I put two beads on the axel and then glue them to the chasis. I found some very nice beads at walmart that were gold plating on the inside. The secret is finding beads that are snug, but not too snug. This method works great. I originally wanted to use washers, but I could never find any with small enough holes.
A religious war is like
children fighting over
who has the strongest
imaginary friend.
04-07-2003, 04:50 AM
Go
no it dosent slow the car down because it is like 1mm away from the little bar so it dosent scrape or slow down.
________
Ford Ecosport
________
Blonde Cam
________
Herb vaporizer
04-07-2003, 08:57 AM
Re: Re: er..
ah...ok then
Custom Tires (back)
04-07-2003, 09:48 PM
NSX Driver!
lol you could have just wrote it down instead of spending the time to make a pic.
04-07-2003, 10:02 PM
they say im slooooow eh?
There is an easier one. You take a piece of a match and stick it in that small slot right behind the rear axle, and slide it over the rear axle. It works too!
04-07-2003, 10:03 PM
Told ya.
I use a small piece of a zip tie to hold the axel in on some of my striped cars.
____________________
Meh.
04-08-2003, 02:44 AM
Go
theres millions of ways 2 fix it but i find puting a tooth pick in it the easyest.
bwsk8
it was easy 2 draw that on paint i'm a pro at using paint.
________
Vaporizer volcano
________
CHEAP CYMA AIRSOFT POCKET PISTOLS SILVER
________
Yahaira live
04-08-2003, 12:01 PM
if you want a more semi permanent fix that actually makes it smoother/quieter/faster than stock pour some jbweld into the entire wheel well. it takes about 6hours do dry and you have to turn the axle about once an hour so it doesnt get cemented in there. it is removable but you have to reglue it back in. once you see how it improves you wont care about gear ratios.
04-08-2003, 12:35 PM
State Property
..i agree. Hogjowlz way is the BEST...your axle will be VERY stable..tight turns,more speed,and its even quieter...WOW
