Old 04-04-2003, 05:32 PM
pdcr's Avatar
pdcr pdcr is offline
Go speed racer go!
charging tri cell
How long should I charge my tri cell? I modded an XV racer charger. (3 double A batts)
Gold Honda Civic Zip Zap:
Old 04-05-2003, 02:26 AM
chelboed's Avatar
chelboed chelboed is offline
Epoch's R Bett'R
If it's a tricell, I would use 6aa's to charge it. Leave it on for aroung 1.5 minutes.
Old 04-05-2003, 02:27 PM
BillyP
I'm not trying to argue, but three AA's was a good idea. You should charge at 1.5V per cell. Anything more is overkill.
Old 04-05-2003, 03:25 PM
chelboed's Avatar
Epoch's R Bett'R
Kay, but when I charge with 4AA's for 1.5 minutes my run time is drastically shorter and my power is noticeably less. When I charge with 6AA's, the cells don't get very warm, so I just figured I would get better run time and power with less charge time and no cell damage. It's worked for me for a long time now, but if you don't want to use more than 3AA's that's cool too. It just won't perform very close to it's full potential. 1.5v is good, but the mah is not enough with AA's. You could do an AC charger with higher mah, like 800mah or so at a low voltage, but I still charge my 3cell car for 1.5 minutes on 7.5 volts with mine.
Good Luck!
Old 04-05-2003, 08:31 PM
pdcr's Avatar
Go speed racer go!
I guess I'll try the 1.5...if that isnt satisfactory then I'm gonna make the 6 AA charger.
Charging the laymans tri cell on MS Pro? Bad Company Bit Char-G / MicroSizers 9 07-23-2003 04:37 PM
charging tri cell BabyKiller Bit Char-G / MicroSizers 3 02-06-2003 04:33 PM
