Old 10-08-2002, 06:47 PM
323iT's Avatar
323iT 323iT is offline
Send a message via AIM to 323iT
Originally posted by batesjm
will the bodies fit a bit char-g?
no they don't fit because Bit Char-g MicroSizers have a larger front end because of the steering mechanizms
Old 10-09-2002, 04:18 AM
MTL's Avatar
MTL MTL is offline
www.d1gp.com
Send a message via AIM to MTL
has anyone seen the new hot wheels commercial for those cars that have decals n stuff on them?
i forgot the name but ive only seen it once and it wasnt a KIT car...
i need to go to walmart
Old 10-09-2002, 12:07 PM
323iT's Avatar
^are you talking about modifiers or muscle machines?
the decals on muscle machines are pre applied. modifiers come with a small decal sheet
Old 10-09-2002, 12:29 PM
go_zz_go's Avatar
go_zz_go go_zz_go is offline
more power!!
well i was yelled at for starting my own thread so ill jump in here the charger can be moded to hold a zip and charge em and the motor works good also the battery is a tomy nicd but it is a little smaller than the zips. so i can get four in my zip i know this is the bits page but i only have a zip and i cant start a thread there so my zip friends i hope you find this if you do instant message me or email and i will tell ya what it can do for ya cause i know these bit boys dont want to hear it espicaly tech lord ya i know they are gay so what its cheap fun
Old 10-09-2002, 05:35 PM
MTL's Avatar
MTL MTL is offline
www.d1gp.com
NO NO
its a HOT WHEELS car....i just saw a new commericial of it...
i know what modifiers and muscle machines are haha..i have a few...and plus they dont make commericials...i think
Old 10-09-2002, 05:56 PM
MTL's Avatar
MTL MTL is offline
www.d1gp.com
umm nevermind, i think i was day dreaming when i thought of it..
because its not on the official hotwheels site
but it was a kool dream though.....
Old 10-10-2002, 12:18 AM
go_zz_go's Avatar
more power!!
hey yall whats up i got one today they do have decals(hot wheels kit) and lots of stuff can be done with the parts first i tore the charger apart and threw away all the stupid timer stuff and moded it to hold my zz charger runnin straight from the 2aa batts that gives me enough juice to charge my 3.6 volts of batterys. and since its straight off battery i can set the charge time. so now my zz controler is just for driving. it was very easy to do and i dont have a bit so i dont know how they hook up to the charger. i just used my exacto knife to cut a sqaure to hold the new charger. a tip on cutting the hard fragile plastic is to heat up the blade first,no broken blades,and it cuts like butter and the 3.0 motor is insane fast and with the antenna mods i truly loose the car outside its gone and gone far
Old 10-14-2002, 11:18 PM
d7onr8 d7onr8 is offline
Originally posted by datamonster
is it just me or fo the K.I.T. racer motors seem to have more power. example K.I.T. 2.6 vs. 2.6 BC-G
I agree with this old post about the KIT 2.6 motor being faster than the Bit 2.6 motor. I originally had a Bit 2.6 and put it in another BIT I had for a present. But I got anxious and just started to switch the motors out and test them at the same time, and there is an obvious speed difference in favor of the KIT 2.6 motor. I know that they are both Tomy products and are supposed to be the same thing but there is a noticeable difference using the same setups.
Old 10-31-2002, 11:46 AM
DraKhen99 DraKhen99 is offline
Send a message via AIM to DraKhen99
Hey, I lost one of my steering springs... will the Hot Wheels K.I.T. Racer's steering spring [does it even have one???] fit my bit? If so, I could save some dough!
-DraKhen99
See my collection of Micro R/Cs:
Old 10-31-2002, 11:58 AM
arch2b's Avatar
arch2b arch2b is offline
TinyRC & Mini-zRacer Fan
kit racers do not have steering. they are made to run in tracks, thus the guide wheels assmembly on the front. do a search on the subject, i know i've seen temporary solutions to your problem posted.
Old 10-31-2002, 12:06 PM
Yeah, I've looked... the best replacement so far has come from QFM, with the shock spring to steering spring mod... i was looking for a real replacement spring. Oh well... I'll just have to make one then.
-DraKhen99
Old 10-31-2002, 04:50 PM
PhillyB PhillyB is offline
ok i just saw KIT at wally world and bought the high speed version - motor seems to be decent - around a 3.0 - the gears thou are wayyy too high - in my two celler it barely starts em - and it gets speed but runs out of room and kills batts quick - tires suck - tomy nicad - i think ive got like 4 now - 4 cells anyone? but are any of the gears low enough to work with the bits?
Old 11-09-2002, 12:12 PM
cowfish_29's Avatar
yellow fish forever!
You could just go out and buy a clone that has magnetic steering at...like walmart or something. The steering springs are about the same. They are only like $10-15, and you get some clone stuff.
Old 11-10-2002, 10:06 PM
microsizer microsizer is offline
Send a message via AIM to microsizer
do they have a website up yet?
Old 11-11-2002, 05:14 AM
Blue Bit's Avatar
Blue Bit Blue Bit is offline
Toy Collector
i had the same experience too when i bought a K.I.T.T. in walmart with a 2.2 yellow and put it on my NSX, and bought a microsizer Lan-Evo with 2.2. The K.I.T.T. 2.2 motor was faster. I returned the microsizer the next day.
NSX-R , FairladyZ33, Auto Modellista, AE86 Trueno,
Calsonic R34, R34(WHT), Evo VII(YLW)
Hot Wheels K.I.T. racing GPXSS Bit Char-G / MicroSizers 4 08-30-2003 10:35 AM
hot wheels. can you use the wheels?? Spanky Bit Char-G Mods and Projects 5 01-10-2003 01:42 AM
Hot Wheels KIT not quite compatible with Z-cars. LCKKN]HT Bit Char-G / MicroSizers 0 11-10-2002 06:21 PM
what speed is the hot wheels kit car??? 1coolskyline Bit Char-G / MicroSizers 4 09-22-2002 11:27 PM
hot wheels k.i.t. cars at walmart catman25 Bit Char-G / MicroSizers 6 09-17-2002 03:06 PM
