Old 09-24-2006, 09:19 PM
lphlp lphlp is offline
actually, yeah, my dummy chassis is just plain old legos...still a kid at heart.
i am planning on using zzse knuckles and modifying them to fit a custom axle end. i will make a cup for the dogbone, the a smooth shaft for where it will rest on the knuckle, and a square tip has a hex for the tire, at the end of course will be a thread for a lugnut.
som details:
for the rear suspension: i will use a dual or tri leaf setup, for a little extra stiffness and durability (since it will pull a micro trailer with my micro boat.) and
xmod truck soft springs in the front with 2-4 coils removed. the support links will be under the chassis....not on the sides like on the bigger crawlers.
my motor set up:
xmod evo servo motor smack in the middle of the chassis with the ZZse 6 tooth pinion, then to the left bottom will be a ZZmt green spur gear and to right botom of that will be anothe ZZmt green spur gear which will have the main shaft in it, but this shaft will not go directly to the tranny. there will be a u-joint cup (hand made) a dogbone another u joint cup and then the actual tranny. but all the shafts will be so short that the power wont be reduced.
i thought th e dogbones were made of nylon too, but how can i make some...?
-Lino
Old 09-26-2006, 04:52 PM
so anyone have any ideas on what to use as leaf springs?? since it needs to be a semi circular flexible metal, i was thinking of the metal the wind up toys have inside....and in doing a single leaf set up; since i noticed how much the little truck would have to stress just to flex a little.
a little change of plans...i am going to do leafs back and front, not coils, i am leaving the coils for my hummer, which will be the same but with smaller tires and less flex.
i am also going to cover up the back of the chevy pick up body and make it look like a 2 door chevy blazer (the full size SUV, not the little one.)
sorry for being such a friggin noob, but what is a slot car??
-Lino
Old 09-26-2006, 05:45 PM
RCdabbler RCdabbler is offline
Sounds like a good plan you have-I want to see the pictures.
I think you have a good idea for the leafs.Are you going to roll one end for the mount and have the other end flat and slide so it works the right way or go all out and make shackles also.
slot cars run on a track with two metal rails that supply the power and are guided by the use of a pin sticking out of the bottom of the car that follows a slot in between the metal rails on the track.
How old are you alpha? (i feel old-sigh....lets just say i was in my late teens when the first RC10 came out) back when I was a kid slotcar racing was the most fun and radio control was very expensive and not very popular and still crude.
Slot cars go wicked fast, I always liked my tracks setup with seperate power supplies for each car so you couldnt have someone brake launch you off the track(thats better to give-than to receive-LOL).
Old 09-26-2006, 06:35 PM
zzultimate zzultimate is offline
Send a message via AIM to zzultimate Send a message via MSN to zzultimate
Sounds good alpha.
I also want to do a leaf spring set up of some sort. I'm experimenting with different thin metals to see how they flex, so far they have all been too stiff.
I remember someone talking about their front set up, well I've figured out mine. It's going to be one piece of brass for the axle, and inside the brass tube will be a solid piece with a u-joint on each end, the u-joints sticking out past the brass tube axle. Attached to the brass axle will be a "C" shape on either end for the knuckle to ride in, and he u-joint will run inbetween the knuckle and the brass axle(it looks like most tttt trucks).
Kinda confusing, isn't it. I'll see if I can find a pic, or draw one.
Xmods:
Old 09-26-2006, 08:39 PM
Hobby shops have music wire that is high tensile and might be used as a spring and it comes in a large selection of sizes.(cheap too)
Old 09-26-2006, 09:21 PM
ill try to get a cheap wind up toy that has a weak wind up system within this week and try out the metal, i found some metal, but it wasnt a flexible metal, it wouldnt retian its shape.....so it was worthless to use as springs...
do you think three gears in enough to pull my little truck?? i mean, with a lot of torque, i plan on using the 6 tooth pinion, and 2 of the green monster truck gear, the drive shaft will come out of the 2nd green gear (obviously) and into some u joints which will link to the axle.
the front axle set up is simple, but i still gotta make it and test it; brass tubing to cover the rotational shaft and gears, E shaped kunckle holders, a the servo set up in the middle with the horn facing the inside of the chassis.my leaf set up will have enough room since the dif ball will be a little to the left and the servo will be in the center.....
YES I KNOW..THREADS ARE WORTHLESS WITHOUT PICS!!!!
i hope to make shackles, luckily, my father owns several industrial sewing machines that he sells and has many spare parts, some of which are similiar to tiny shackles and the part that holds th eleaf to the axle, (in very tiny dimensions...) and universal u-joints.
-Lino
Old 09-27-2006, 09:27 PM
what are you guys using for driveshafts?? i was thiking of using xmod evo dogbones as my shafts from the tranny to the axles...what do you guys think???...flexibe enough???
i already set up my four gear tranny, i took most of the gears from a disassembled xmod gen 1 servo.
anyone thought of any ideas for tiny shackles??
-Lino
Old 09-28-2006, 05:33 AM
Shackles should be easy to make arnt they just two flat pieces with holes drilled in them.They can be made most any length.granted the better ones are one solid piece shaped like an H but that isnt really needed.
As you can see in the pics I used Xmod driveshafts but they arnt done yet, I'll finish them once I get the chassis cut so they fit right.I also used Xmod bearings as much as possible.
Thats how far I have gotten on my ZZmt.I plan to have two green idler gears stacked on top of the green axle gear(shown in pic) and two motors driving it.
I'll be able to use almost any combination of gears once I get a new piece turned on the lathe that goes into the axle drive gears.
I also have to make the T-case and be able to remove one of the idler gears, drop the motors down.
I'll try to get the drawings up this weekend of the T-case.
The plan is to be able to have two idler gears or just one idler gear or for all out speed no idler gears, just the ZZmt axle gear.
LOL I was working on my ZZawd project yesterday at work sitting in the work truck dremeling pieces.
Old 09-28-2006, 06:08 AM
alpha_003
Have you seen the post I have in the ZZmt forum on my ZZmt project.
Old 09-28-2006, 09:32 PM
rc dabbler, did you make those little shafts from the awd dogbones or the rwd ones?? because i have some junk parts and happen to have those, but i cant seem to figure out how you did it, i was initially planning to use xmod evo dogbones but you kinda reminded me how small the gen 1 dogbones are, so thanks...i have just decided that im doing two chassis, one with coils all over and a rear motor with shaft to the front and a central motor dual shaft with leafs all around.
the first one will most likely be composed of a heavily modded zzse servo, with an additional gear (maybe.) and a very simple coil and link set up. this one will be a much simpler design and will be a lot less capable but realistic......hope i have enough time before chirstmas, as i am going to NC and hope to try them out, along with my other R/C in the snow
-Lino
Old 09-28-2006, 10:57 PM
Snake Mod Snake Mod is offline
Send a message via MSN to Snake Mod
Wow This Looks Like 1 Of those "wish" mods you know hope someone sticks to it and gets it done
MOTORWORKS
[color=green]
Old 09-29-2006, 03:13 AM
Those little shafts(U-joint/dogbone) are from the AWD kits and the two used in the center gear are shaved to fit together in a 3mm hole which is just a piece of aluminum that I turned down to fit into the ZZmt green axle gear.
I plan to change it a little, the aluminum piece right now is just slightly smaller in diameter than the Xmod bearings but I want it so I can use any ZZmt axle gear there so I need to remake it slightly larger than the 6mm bearing so I can slide the gears over the bearings to change them.
The gears HAVE to be able to slide over since the U-joint shafts will get epoxied into that aluminum piece to lock it all together.
I havnt cut the dogbone ends off yet but I will once I get a chassis done.The shafts in between the T-case and axles will need to be sliders to keep it from binding as the suspension moves.
I hope to get more done on my ZZse-AWD project this weekend as well as do a little more on my ZZmt project.I need to finish the chassis pieces for the ZZ-awd and get it put together enough to show a progress pic.The little A-arms are so tiny and drilling the hinge pins should be interesting.If I can get it all to fit by cutting it out by hand then the CNC cut version should be excellent.I see the ZZse servo is going to give me trouble since it is so big, not sure what I'll do with it yet.
Old 09-29-2006, 04:18 AM
I have to find these, they make two. JADA TOYS
Those tires are exactly what I want for a 1/64 RC buggy project.
This would work also.
I hate the truck(tires mainly) but the sandrail and trailer are cool.
LOL-low profile tires on lifted trucks just looks stupid.
I wonder if those are out there anywhere yet.
I'll go hunting this weekend for them.
I will make a 1/64 sandrail RC someday (soon I hope)
Old 09-29-2006, 05:05 PM
that hummer body looks useable, especially if i get bored of the white chevy body. i also hoped to find a tiny toyota body, but thats going to b ehard. that trailer is sweet too....i would buy it just to put another zip zap on it, maybe my mustang......i already got my tranny gears together, and have my servo ready.......and my coils (for my hummer.)
those tires look nice, but the hummers look nasty, i wish i could build a 2wd buggy too, and a mini ATV....oh well too many projects, too little time....i justwanna get my mini 4wd blazer done by christmas....
-Lino
Old 09-29-2006, 05:47 PM
I dont know if those are in stores yet, the site said "coming soon" but I bought a couple of things the other day that I seen that said "coming soon"
My hope is that the buggies are in the stores somewhere.
The hummer body is OK i just dont care for hummers the thing I hate to see is a lifted vehicle with those low profile tires, just looks stupid to me.
help - zzse not working!! xanderono ZipZaps SE 1 12-01-2006 07:42 PM
AWD problem LightFetish XMODS 4 05-04-2006 08:30 AM
AWD with Resistor Mod for steering cool_cars XMODS Mods and Projects 20 12-04-2004 04:10 AM
AWD questions Lucky7 XMODS 6 09-24-2004 11:46 PM
4.8 Volt ZZSE urbanavenger ZipZaps SE 2 10-03-2003 12:13 PM
