Old 05-21-2003, 05:13 AM
BabyKiller's Avatar
new soldering iron
i was at rs yesterday and i pick up the duel wattage soldering iron(15w and 30w)and i was soldering for 2 houurs straight last night and the tip turned all gold and purple in one spot how bad is this
+ (4.8v)
Old 05-21-2003, 07:02 AM
Havok's Avatar
Havok Havok is offline
OlD SkOoL
Send a message via Yahoo to Havok
I think every soldering iron I've ever owned has turned colors, I haven't been blown up yet
"On a newly painted fence,
I sat sticking to the rail,
not knowing who to blame,
not knowing who to kill,
for the criminally insane,
there is no free-will."-
written by my wife__________________________
Check out my RC pics at:
Old 05-21-2003, 08:48 AM
kwikbb's Avatar
kwikbb kwikbb is offline
smoove operator
Me too, they've all discolored. I used to have the same dual wattage iron, it's great because it comes with the stand and power is switchable at the base, instead of having to unplug it all the time. And it doesn't break the bank either.
Old 05-21-2003, 11:54 AM
Awaken's Avatar
Awaken Awaken is offline
Feh
Send a message via AIM to Awaken Send a message via Yahoo to Awaken
specking on batteries blowing up...i was chargering my 6 cell stick pack on a amp charger (lol) and i forgot about it and it blow up!! so i went outside to see what happend and there was half the battery still there then all of the sudden it blow up! i was like 2 feet away from it....damn that hurt.. i had metal shaving stuck in my arms and neck for a long time..
Give me a moment in which I well never AWAKEN
Old 05-21-2003, 12:23 PM
nrmcj's Avatar
nrmcj nrmcj is offline
Rice Me
ohhh hey is that 15/30 watt iron any good (from rape shack)...?
i used my buddies soldering iron last nite to fix a wire... variable voltage all the way up to 300... @_@ ... scared the crap outta me, cuz i've never soldered before...
but yeah, anyway... is that iron from radio shack a good deal?
Old 05-21-2003, 01:08 PM
hogjowlz's Avatar
hogjowlz hogjowlz is offline
i used to have a radioshack iron and it works fine for bits. as far as the discolored stuff, you need to keep your tip clean which can be done by applying some solder on the tip and then wipe it off on a wet sponge. do this often. it will make the tip last longer and more importantly will make soldering easier.
Old 05-21-2003, 01:13 PM
kwikbb's Avatar
smoove operator
lightly sanding the tip is good too
Old 05-21-2003, 02:22 PM
BabyKiller's Avatar
yeah its good and i also have a 300watt soldering GUN but thats just crazy the 15/30 watt is great and i got it for like $8 or $9 and i bought led free solder(me dont like cancer and poision)
also like the whole metal part was changing color
+ (4.8v)
Old 05-21-2003, 02:49 PM
metsrule119's Avatar
metsrule119 metsrule119 is offline
Actually, they suck^
Send a message via AIM to metsrule119
I have that same 15/30 iron.... mine changed all kinds of colors too
1 Xmod w/ the works
2 Microsizers
1 Zipzap
1 Zipzap SE
1 Toy East Mini Cooper
1 Precious Clone
Old 05-21-2003, 02:53 PM
hogjowlz's Avatar
i dont think led free solder is as conductive or strong. but ya it is toxic(especially for little kids) so clean up right after you are done.
Old 05-21-2003, 03:02 PM
BabyKiller's Avatar
led free toxic or leaded?
edit: do you think im to little im 11 and my first soldering job i fixed a steering wire am i a born solderer?????
+ (4.8v)
Old 05-21-2003, 03:38 PM
RobotGT's Avatar
RobotGT RobotGT is offline
SUPREME RULER
Im 13 and the second time I soldered I was duel cellin my car. Im prolly gonna get a butaine solder soon, my bro can get em cheap from the snap-on guy at the ford dealership where he works! But anyway mine changed gold so now my soldering pen is all blinged out !
full size zz wheels
Old 05-21-2003, 04:09 PM
BabyKiller's Avatar
i saw a butane at raidio shack for $15 was so good about them?
+ (4.8v)
Old 05-21-2003, 04:27 PM
RobotGT's Avatar
SUPREME RULER
they heat up faster, or at least thats what i heard.
full size zz wheels
Old 05-21-2003, 04:39 PM
chundermonkey's Avatar
chundermonkey chundermonkey is offline
Mooooo!!
heat up faster? humm maybe.. i know that if you get a good soldering station (iron) that has the variable wattage. some of which run up to a couple hunderd dollars... they heat up instantly...
sanding the tip is good. but after you do this, put some solder on it and wipe it with a wet sponge.. this will help you hold solder on the tip of the iron. which will allow you to just touch the iron to the parts you want to solder.. just touch, the solder will leave the iron, and then remove almost immediately... works great for me.
discoloration is normal.. this is what happens to metal as it is heated and cooled. its also called tempering.. if youve ever heard of tempered steel. it kinda goes through the same process.. heated up to a certain temp. and then cooled. sometimes cooled extremely fast by using water... or other cooling liquids.. anyway tempering is different for different metals and applications...
Soldering iron accident (serious) Char-g Ace Bit Char-G / MicroSizers 23 07-01-2003 12:45 PM
Soldering Iron nrmcj Bit Char-G / MicroSizers 17 02-13-2003 06:54 PM
$1 20watt soldering iron zclonedude Bit Char-G Mods and Projects 4 01-18-2003 03:51 PM
