Old 05-14-2003, 08:19 PM
BitZipAddict BitZipAddict is offline
tri-cell
whats the best way to tri-cell a zap. How do you wire it correctly. Best way to charge it. Please post tips and all ur 3-cell pics.
Old 05-14-2003, 10:29 PM
Turboas Turboas is offline
Send a message via AIM to Turboas
Try this:
http://www.geocities.com/pikamoy/BuntaZZmods.html
It's the famous Bunta's guide. It's really basic, probably the best. I'm a newbie too, but I been looking at ways to try a dual cell and I'm gonna do it once I get the stuff together. Here's some more that might help too:
http://www.driftkingshop.com/dualbatterymod.html
http://tinyrc.com/forums/showthread.php?threadid=6045
I guess the tri-cells are the same, but with a third battery between the two. You just hook it up, + end to - all the way through. I'm sure the cells have to be the same too. The rule of thumb I heard for multi-cells is 2 AA's in the charger for every cell. Like I said, I haven't done any of it for myself, so listen to me or not. Whatever. But this is what I've found. Hope it helps.
My humble ZZ collection:
-Lowered champagne Civic
-Silver 350Z
-Blue RX-8
-Motor/Gear upgrade kit w/ 2.8 motor
-2F2F kit w/ 3.4, Evo, & Eclipse
-2F2F Skyline and S2000 bodies
-Awesome RC 2F2F Lancer Evo
Old 05-14-2003, 10:40 PM
Well, i have already done 4 dual cells---i just wasnt sure on tri-cell.
Old 05-15-2003, 12:42 AM
Calsonic_racer Calsonic_racer is offline
MASTA POOOOOOOOOOOOOOTANG
uumm actually tri-celling a zap is probably the easiest dual cells i have ever done. check this out. have you seen striders dual cell? well see this si how you do it ill show you how i tri-celled my zip zap. First as of any normal dual cell break off the tab that touches the - side of the battery. NOT ALL OF IT just the part that touches. you can do that by bending it up and down until it wears and breaks. next you solder a wire on top of that - contact and solder it to the back of one of your 3 batteries. next solder a wire from the + side of that battery to the - side of your second battery. and then solder another wires from the + side of that battery onto your final battery on the - side. now heres the tricky part kind of. only hard part is to avoid breaking the wires on the pcb. get your third battery ( the last one to be soldered) and stick it in the original battery slot. next lasy the other 2 batteries vertically laying down and it will all fit like this =| get it? these are the two batteries = this is the third battery that goes to the normal car | if you lay them right they will look like this = | i would post pics but i dont know how lol. i made one right now in my microsoft painting shop and i dont know how to paste it here so srry. oh also USE NIMH CELLS NOT NICD OR ELSE IT WILL SUCK AND MOSTLY LIKELY NOT WORK!!!!! I REALLY REALLY REALLY RECOMMEND NIMH CELLS.
MICROSIZER PRO: 2 SPEEDS, 1.3 NIMH, 49 MHZ, SKYLINE R34 GTR custom paint, pull back wheels, blue head lights
MICROSIZER SPORT: 1.3 nimh, rest is stock
panther= 2.4 nicd, rest is stock
MEGATOYS rc: rest is stock
bitchar-g: rest is stock
Old 05-15-2003, 12:19 PM
MadScott's Avatar
MadScott MadScott is offline
The easiest way to triple cell your zz is to usethe layman's cell mod.
"When I'm through with you kid, you're gonna piss lightning and crap thunder!"
Old 05-16-2003, 04:57 PM
flatlander_14's Avatar
flatlander_14 flatlander_14 is offline
2 Slow and 2 Curious
Send a message via AIM to flatlander_14 Send a message via Yahoo to flatlander_14
i did a layman's dual cell to my bit clone (3 wouldn't fit, chassis wouldnt flex enough) and it is awesome. less runtime, but it makes up for that in speed. i already test fitted 3 cells in my zip chassis and it will work fine in there. im picking upa 350z zip this weekend and im gonna change the antenna, tri cell it, and maybe a few other things so we'll see how it does
He who run in front of car get tired
He who run behind car get exhausted
He who stand on toilet get high on pot
Old 05-27-2003, 07:01 PM
your basic wiring is correct, but the charger has a + and - terminal also. you may need to switch which way the batteries are charging.
btw 3 celled zips rule!!!!
