Old 05-11-2003, 10:56 AM
BabyKiller's Avatar
fixing steering problems
on my duel cells of i dont take off unboosted they will imedditly spin out and when they dont they go like 1foot and spinnout and this is a problem with all my cars with a 2.6 or higher except my motor works which back tire are as huge as ass
+ (4.8v)
Old 05-11-2003, 02:04 PM
shanly
lloooooonnnnnnggggg sentence there man,maybe you should try to add a second steering spring cuz that will help the car go straighter and it will be better and much easier to control if that dont work you should consider making it a stright drag racer and block off the steering by getting some rare earth magnets and adding one magnet to each side of the stock magnet that will not allow the car to turn anymore and it will be good for doing straight runs (thats one LONG sentence)
Old 05-11-2003, 02:06 PM
BabyKiller's Avatar
all my duel cells have 2 steering springs except one which has 3!!!!
+ (4.8v)
Old 05-11-2003, 03:44 PM
nrmcj's Avatar
nrmcj nrmcj is offline
Rice Me
make your tires CLEAN... the reason for spinouts is loss of traction to the rear wheels... remember, you're going to have dirty tires after about 5 seconds unless you clean the surface ur running on
Old 05-11-2003, 04:30 PM
bdebde's Avatar
bdebde bdebde is offline
That's all folks
Hard tires in front help also. I like the ribbed ones from the microsizer tire set. I also like zip zap all season radials from zip zap tire kit for the rear.
That's all folks!
Old 05-11-2003, 09:21 PM
BabyKiller's Avatar
i clean them whenever i cant po a wheelie(ever 2min)
+ (4.8v)
steering problems? i have the answer! SkyLiNEz 4-eva! Bit Char-G / MicroSizers 6 07-17-2003 04:30 AM
Steering problems Zephyranthes Bit Char-G / MicroSizers 7 03-26-2003 09:18 PM
please help with steering problems Snow Bit Char-G / MicroSizers 2 12-17-2002 12:02 PM
Steering problems Go0ty ZipZaps 1 10-08-2002 08:20 PM
