Old 05-10-2003, 09:48 AM
ugh's Avatar
ugh ugh is offline
Holy Crap!
Send a message via AIM to ugh
Failed Attempt at a Dual Cell, Help!
Well, last night I tried to dual cell my Pro, but it didn't work. I used QFM directions, and I made the controller mod. When I charged it up and ran it, it ran like a single cell. So I removed the batteries, but now I have solder on my batteries (how do I get this off?) that makes them look nasty. Plus I melted the chassis a little and that wasn't good. The interesting thing was after I made the controller mod, the charge light still came on when I charged. What is up with the controller, what is up with the batteries, and how do I get solder off of the battries?
Old 05-10-2003, 10:25 AM
2fast2furious59's Avatar
2fast2furious59 2fast2furious59 is offline
Independent Motorsports
Send a message via AIM to 2fast2furious59
if you feel lucky and u have a solder remover, you can try to heat up ur soldering iron and heat up the solder and use a solder remover thing to get it off..it should work
Old 05-10-2003, 11:14 AM
kwikbb's Avatar
kwikbb kwikbb is offline
smoove operator
Re: Failed Attempt at a Dual Cell, Help!
That right there is an indication that there's a connection problem between the 2 cells, the led will not come on if all is well with the connections.
if you have a dremel, you can sand it down... that's what i've done in the past.
Old 05-10-2003, 12:55 PM
TypeZer0's Avatar
TypeZer0 TypeZer0 is offline
0reZepyT
i suggest running over to radioshack and grabbing copper braid, it's only a couple bucks. place the braid on top of the solder you wanan remove and take your hot iron and heat the top of the copper braid, the solder underneath will quickly melt and get sucked onto the braid. remove the iron and braid quickly so you don't heat the battery too much. as for the dual cell acting as a single cell, i've encountered this twice in a row on two of my dual cell cars. it seems as though i needed to "jump start" the second battery (it always seems to be the second battery i added on, dunno y) but all i did was charge it up once fully and run the car until the charge wears off completely and charge it again. the second or third time you charge it, the second cell should stop acting as a simple connection for your first battery to send energy through and start giving some juice for your car. either that or try to "jump start" the second battery with a quick (less than a minute) charge at 4.5 or 6 volts and try the procedure i jsut described above. it works for me and i've had no problems since
Friends (Joey's Bag)
Rachel: Exactly! Unisex!
Old 05-10-2003, 01:25 PM
charliebrown's Avatar
I'm really sorry to hear that you ruined your car....But hey, that's cars for you..... Very hard to understand...lol
Old 05-10-2003, 02:51 PM
Lord_Nick_D's Avatar
I cant stop modding
I broke a car trying a duel cell too
I know how you feel
I broke the charging tabs off the bottem
I gave up on trying to fix them anyone have any Ideas on what I can do to put in a battery pack that i can charge separatly or something
Old 05-10-2003, 10:33 PM
DarkTari's Avatar
DarkTari DarkTari is offline
BitPimp Enforcer
Re: Re: Failed Attempt at a Dual Cell, Help!
Hey Kwik,
I did the tx mod last night, removing the charge plate wires from the circuit board and soldering directly to the batt terms and when charging, the timer light still comes on and works ?????
And it does charge. It's a clone tx if that makes a difference but what gives? I thought the charge light wouldn't work either after mod is done as per the mod directions.....
DarkTari
If It Don't Fly....."MODIFY"!
Old 05-10-2003, 10:39 PM
kwikbb's Avatar
smoove operator
Re: Re: Re: Failed Attempt at a Dual Cell, Help!
Originally posted by DarkTari
Hey Kwik,
interesing, i don't have experience with the clones so it's very well possible! the results that i've gotten we're from the tomy controllers, but bypass may not affect the clones in the same manner...hmmm
thanks for bringing this to our attention DT!
Old 05-10-2003, 11:18 PM
DarkTari's Avatar
BitPimp Enforcer
I'll mod an MS tx and letcha know my results....
DarkTari
Old 05-11-2003, 09:34 AM
bjv5 bjv5 is offline
The bypass mod does work on clones. I wouldn't understand why it won't work. This is just like putting the charger directly on a 3 cell or 4 cell battery pack to charge it.
Old 05-12-2003, 09:52 AM
DarkTari's Avatar
BitPimp Enforcer
Yes I said it works (does charge). My comment was about the charge light still working after the mod was done. According to the instructions, the charge light is not supose to work after the mod is done because you're bypassing the Tx circuit board. But like I said, my charge light still works in the clone Tx. Now this mod was illustrated on a Bit Tx which may be configured different from a clone Tx. Doesn't matter to me, as long as it charges!
DarkTari
which dual cell should i do, laymans, external, internal etc eman1 Bit Char-G / MicroSizers 11 09-02-2003 07:42 PM
My First Attempt At An Internal Dual Cell..... Without a dremil neo_m Bit Char-G / MicroSizers 25 04-14-2003 11:49 PM
Laymans dual cell vs. traditional dual cell Zephyranthes Bit Char-G Mods and Projects 6 02-18-2003 06:12 PM
Dual Cell conversion failed :( DioXidE Bit Char-G Mods and Projects 3 01-06-2003 01:40 AM
