Old 09-21-2002, 12:00 AM
1coolskyline 1coolskyline is offline
Send a message via AIM to 1coolskyline
problems with new wrx tomy bit
I just got my gf the official tomy bit char g and i have a problem. Her steering adjustment is all the way towards the passenger side of the bit. Well it was this way when we got it new. My question and problem is her car is pulling slightly to the driver side just slightly. Well since the steering adjustment is already the whole way in the way i need to correct it what do i do? Is there a remedy for this? Please help me out fellas i am not stupid i used to race big rcs monste trucks and sedans i am very mechanically inclined thanks in advance. lata
ps it steers fine i just need to fix the steering. please help
where ever you go there you are!
Old 09-21-2002, 12:09 AM
MTL's Avatar
MTL MTL is offline
www.d1gp.com
Send a message via AIM to MTL
best thing i do is just open up the chassis and take out the steering spring [clean it up with tape if there is junk on it] and then just put it back again..
Old 09-21-2002, 08:20 AM
if you read my post you would see its brand new and the steering adjuster is and was all the way towards the passener side of the bit. And her bit is pulling slighty to the drivers side. Its not doing this cause its dirty its brand new. Anyone that knows how to fix this please help i need to know if i have to open up the steering how to do so and what to mess with inside thanks in advance.
Old 09-21-2002, 09:19 AM
killboy's Avatar
killboy killboy is offline
You might try a couple of things before you open it.
Move the adjuster back just a hair. I've heard of this working for people...it's as if you can adjust it TOO far.
Move the adjuster even more to the side. It will lift the little white tab up and out of the normal recessed area, but it may work.
Layda,
Darryl
Old 09-21-2002, 10:00 AM
well ill try that i hope i can fix this its not pulling terribly but it is still pulling. Ill try it and post what happened thanks guys.
Old 09-21-2002, 02:19 PM
mr0072003 mr0072003 is offline
does not matter that it is new....sometimes Sh@T happens. My initial D set was the same way.....I took it apart and put it back together....and now its fine......there ahve been sveral times were out of the BOX I have to immedialty open it up and re-seat everything.....so far I have fixed 3 TOMY cars and killed one like this.....be careful
Old 09-21-2002, 02:45 PM
tinyrc's Avatar
tinyrc tinyrc is offline
This is a common problem, usually caused by an off-center magnet. If you are certain that the trim cannot be made to work, you need to open up the front end, and make sure the magnet is perfectly centered, and that neither of the coils are away from their proper places.
Old 09-21-2002, 04:36 PM
Tortoise-Licker Tortoise-Licker is offline
I had a strange steering pul on my booster but decided to live with it, until when mounting an extra Battery I snapped two of the steering coil wires(clumsy me) After carefully soldering the ends together I found that my steering has rectified itself. Also has anybody tried to remount the coils further apart by drilling out holes behind them. In order to give a wider steering track?
MY Custom Bit Supra
Gold Springs
Teal gears
Fury motor
Large front wheels
Soft fronts, mid rears
Custom heat sink
Whip attenna
Advanced Mike Williams Light Kit
120mh Battery
Old 09-21-2002, 06:53 PM
i fixed it. I opened it up centered the steering adjuster and put it all back together I tried it out it worked great. lata guys and thanks a ton
Old 09-21-2002, 07:10 PM
Love to hear everything is good....nothing wors than a non working 30 dollar toy....
MOSFET / Dual cell pre-modded Tomy Bit Char-Gs for sale micro_Amps For Sale/Trade 2 08-24-2003 10:16 PM
Bit Char-G: FAQs (Updated: Jan 6th, '03) Namuna Bit Char-G / MicroSizers 15 08-14-2003 11:04 PM
Price gouging on Import Tomy Bit Char-Gs!!! DraKhen99 Bit Char-G / MicroSizers 15 11-22-2002 10:06 PM
tomy bit char-g built to last!! lanevo7 Bit Char-G / MicroSizers 12 10-18-2002 06:01 PM
