Old 04-30-2003, 01:43 AM
bloodyroots's Avatar
bloodyroots bloodyroots is offline
Question What's the best Mhz to run with...
What's the best Tomy Bit-G Mhz to run with MS pro Mhz 27 and 49 at the same time? I've tried the 57 Mhz booster with success, wondering if the other Mhz would run as good (No interference).
Old 04-30-2003, 06:32 PM
cowfish_29's Avatar
yellow fish forever!
as long as a person with a given frequency (say 45mhz) and a similar frequency (49mhz) are not BOTH very close to a 45 or 49mhz car, then you should be OK. A good idea is to stand at opposite ends of a track if your racing or something.
Old 05-01-2003, 10:22 AM
hogjowlz's Avatar
hogjowlz hogjowlz is offline
Retarded Stunt Driver
also the higher the frequency the further the range(in theory).
Old 05-01-2003, 11:27 PM
cowfish_29's Avatar
yeah, but not all controllers are created equal....just a combonation of hit and miss and getting the right controller from the right time period...i got a 4ch that has 3 ft range...angers me
Old 05-02-2003, 10:09 AM
SlowbutCourious's Avatar
State Property
any reg. bit i have does not intref. with any booster bits ...i fianly had some interferience with a 57mhz shen and a 27 mhz Ms but this only happend 1 time tho...
Old 05-02-2003, 10:15 AM
hogjowlz's Avatar
ive seen intererence between diffrent brands before. higher frequencies dominate lower ones.
Old 05-05-2003, 08:31 AM
e_lm_70 e_lm_70 is offline
Send a message via Yahoo to e_lm_70
What ?
It is the other way around !
Low Freq need less power for same range ... since power is fixed bigger range could be achieved only by lower freq !
Problem : 27MHz already used by other Radio stuff, like CB , so the 27MHz could be the most noisy freq ... so could result the worst range ....
e_lm_70
Old 05-05-2003, 08:34 AM
27MHz and 57 are under high interference because:
Transmitting at 27MHz means send an armonic at 54MHz
Transmitting at 57MHz means send an armonic at 28.5MHz
The power of the armonic is normaly produce a rage of few cm around: 20cm to 60cm !
e_lm_70
Old 05-05-2003, 12:59 PM
hogjowlz's Avatar
lower frequency radio waves need more power to move through the air.
look at the new 3ghz cordless phones that can go 1000yds from the base but the old 900mhz ones would only go a few hundred feet.
this is the same principle.
27 mhz vrs. 49 mhz or is it Regular vrs SE Sleeping911 ZipZaps SE 4 08-13-2004 09:14 PM
02 MHz and other odd MHz noxorc Bit Char-G / MicroSizers 3 02-23-2003 05:49 AM
MHZ Modification? ZippyZappers ZipZaps 7 02-22-2003 05:29 AM
35mhz crystal worked on 27 mhz transmitter ejaf ZipZaps 3 12-11-2002 08:30 AM
range of 27 MHz versus 49 MHz gRC ZipZaps 12 09-30-2002 06:33 PM
