Old 05-02-2003, 12:41 AM
Zephyranthes's Avatar
Blitzer Sonic
Steering problems because of pcb
I dropped my Zipzap 1 and a half feet off the floor. It was a very minor fall, so I didn't have the slightest hint of damage. Well, my car wouldn't steer left anymore. I checked the wiring and everything seemed fine but it still didn't work. I resoldered on all the steering wires, but that didn't do anything. I wa starting to suspect the pcb board was having problems. I switched the left and right, and now it turns left but no right. That proved that it was the pcb that was having problems. What's wrong and what can I do to fix this?
Old 05-02-2003, 06:17 AM
Buzzbait's Avatar
Buzzbait Buzzbait is offline
I wouldn't say that you proved the pcb to be bad. Here are some possibilities:
1. Steering wire leading to the positive terminal on the pcb isn't making contact.
2. Steering wire leading to the appropriate left/right terminal on the pcb isn't making contact.
3. One of the steering coils came unglued in the front end of the car.
4. One of the steering knuckles, or something else integral to the steering sytem, has a nasty gash in the plastic, thus preventing the steering from working properly.
5. You have a short in one of your controller buttons.
Old 05-02-2003, 06:33 AM
charliebrown's Avatar
Actually it is a fact that when magnets are dropped, they can lose their magnetism. So maybe you need to make new steering coils, or something.
"What did you write for number five on FRanklin Roosevelt?"
"I wrote down that he was one of our greatest presidents."
"Do you really think that?"
"No...but I've learned never to badmouth a president on a history test."
Old 05-02-2003, 09:56 AM
Blitzer Sonic
Well, if I tough the steering wire to the negative contact, it turns. So it is the pcb.
Old 05-02-2003, 10:03 AM
Buzzbait's Avatar
I seriously doubt that a tiny fall took out the pcb.
Old 05-02-2003, 10:44 AM
SlowbutCourious's Avatar
State Property
i had the same prob with my 911 ..1 of the steerin wires broke off the coil u could not even see it was broke..until i looked with a mag.glass 4 15 min.
Old 05-02-2003, 11:54 AM
cj1267's Avatar
cj1267 cj1267 is offline
CJ's Hobbies.net
Send a message via ICQ to cj1267 Send a message via Yahoo to cj1267
Had this happen to me too and the magnet shifted to one side.
Just reseat it and add a tiny drop of CA glue (super).
Old 05-02-2003, 03:28 PM
MBHockey MBHockey is offline
Send a message via AIM to MBHockey
Yes it is a fact if you drop a magnet it can become demagnatized. This being such a small magnet, it probably wouldn't take much of a fall to demagnatize it. I think you should just try to find a new one of the pieces the magnet fits in.
Old 05-02-2003, 04:55 PM
AUDI-TT's Avatar
AUDI-TT AUDI-TT is offline
XMOD AUDI TT (my wish)
im just wondering...
why exactly does it lose it's megnetism???
Old 05-02-2003, 06:03 PM
Azimov's Avatar
Azimov Azimov is offline
I process, therefore I am
When a magnet is originally magnatized, all of the electrons in the metal are put into a miniature military formation with all of the north and south poles pointing in the same directions. When you drop it, or give it a good enough wack, the electrons become jumbled again and the magnetic field is gone.
Old 05-02-2003, 06:09 PM
dabigpig's Avatar
dabigpig dabigpig is offline
i thought u had to hit it really freakin hard like throw it at concrete or hit with a hammer for it to lose it's magnetism
*** AMC Veteran ***
-- ^-_-^
Old 05-02-2003, 08:30 PM
Blitzer Sonic
The magnet isn't demagnetized. If I touch the wire to the negatvie contact or switch them around, it works turning in the direction.
Old 05-02-2003, 08:52 PM
dabigpig's Avatar
perhaps you're controller button broke at the same time as the car droped and it's really something in the controlla. just shootin out random thoughts.
*** AMC Veteran ***
-- ^-_-^
Old 05-02-2003, 10:09 PM
Azimov's Avatar
Yep, you'd need a really good whack to demagnatize the magnet. I don't think that's the problem here anyways. I'd put my moola on a broken wire going to, or inside the coil.
Old 05-02-2003, 11:55 PM
Blitzer Sonic
The coil isn't broken because it works if I stick it on the other steering wire contact.
steering problems? i have the answer! SkyLiNEz 4-eva! Bit Char-G / MicroSizers 6 07-17-2003 03:30 AM
Steering problems Zephyranthes Bit Char-G / MicroSizers 7 03-26-2003 08:18 PM
Another Sucessful PCB Transplant marc515192 Bit Char-G / MicroSizers 6 10-27-2002 09:22 PM
Steering problems Go0ty ZipZaps 1 10-08-2002 07:20 PM
