Old 04-26-2003, 10:48 AM
SlowbutCourious's Avatar
State Property
dual cell woulnt charge
my internal dual cell was runnin strong untli last nite!.. now it woulnt charge.. i can take the cells out and charg them but that got old after doin 2 times... has this happend 2 anyone else?..what happened
Old 04-26-2003, 01:52 PM
bdebde's Avatar
bdebde bdebde is offline
That's all folks
What kind of charger are you using for your dual cell. It will not charge on the stock charger unless you modify it.
That's all folks!
Old 04-28-2003, 03:49 PM
State Property
i added the extra batt. 2 the controler it was chargin and now it woulnt this is only with my internal dual cell the other 1 charges fine
Old 04-28-2003, 04:05 PM
hogjowlz's Avatar
hogjowlz hogjowlz is offline
Retarded Stunt Driver
either somthing came loose or you have a short.
Old 04-28-2003, 04:06 PM
State Property
i cant find anything loose ..what kinda short?
Old 04-28-2003, 04:11 PM
hogjowlz's Avatar
well my 2000gtr hit something hard(headers or something from a mopar) one night and then it started to act real funny. it turns out the solder joint from the motor terminal cut through the battery insulation. i have a vid of the accident ill have to post it soon.
Old 04-28-2003, 04:22 PM
State Property
!!thanx hogjowlz!! i'll check 4 that..i was crashin into everything that day 2..
Old 04-29-2003, 10:32 AM
State Property
well thats NoT it.. ..anyother reasons why this car is not chargin ..i'm ready 2 smash this thing with a hammer
Old 04-29-2003, 10:44 AM
hogjowlz's Avatar
desolder and resolder
you never know
maybe the board is fried maybe a battery went?
Old 04-29-2003, 10:51 AM
State Property
thanX AGAIN Hogs i'll replace the pcb and go from there..U must have ESP or something ( someone is havin a problem on tiny rc hogs is pulled 2 the comp.2 offer his expert wisdom )
Old 04-29-2003, 11:11 AM
hogjowlz's Avatar
thats because ive broken a whole lot of em.
Old 04-29-2003, 11:39 PM
State Property
ok that car is now in bits.. replaced the pcb still nothing resoldered everything but the chips on the pcb..i just ordered2 more clones and am just startin over
dual cell bit charge hpbw2k Bit Char-G Mods and Projects 0 06-25-2004 03:41 PM
how long should i charge a dual cell with a 6volt charger? eman1 Bit Char-G / MicroSizers 2 09-01-2003 08:23 PM
My Dual Cell Won't Charge! ugh ZipZaps 5 05-10-2003 11:43 AM
Can stock charger charge Dual cell?! nrmcj Bit Char-G / MicroSizers 13 01-13-2003 01:49 PM
