Old 04-24-2003, 11:13 AM
350z-zz 350z-zz is offline
nother question
how do you know if the car has the new pcb if they are still sealed in box. im thinking about getting another zz and want to make sure i get the new pcb, i already have a 350z and Do not want a x-men rx8. so besides those, which have the newer pcb.
Old 04-24-2003, 01:31 PM
Clint Clint is offline
Wide Open Throttle
the black cobra and the gold civic have it too.
why dont u want the rx8? it comes with a red motor stock..and u can just swap the body with something else if u dont like it.
Old 04-24-2003, 02:16 PM
Labmonkey's Avatar
Labmonkey Labmonkey is offline
Tortured Primate
I agree with clint....don't rule out the rx8 just because you don't like the body...with the setup it comes with it is a nice fast car.
Also, my rx8 is faster than my buddy's champagn civic with the same motor/gear combo....faster acceleration and slightly better top speed.
Albert Einstein
Old 04-24-2003, 02:20 PM
NatakuARN's Avatar
NatakuARN NatakuARN is offline
Anime RPG Nut
The civic is slow as dirt, I would not recomend it. I have a Black mustang, Civic, 350z and the RX8 and I would have to say the RX8 is the best of them all.
Old 04-24-2003, 05:30 PM
ViperKid's Avatar
ViperKid ViperKid is offline
Redneck Drifter
plus the controller is shiny and you can see if you have stuff stuck in your teeth
Old 04-24-2003, 05:58 PM
Azimov's Avatar
Azimov Azimov is offline
I process, therefore I am
I bought a new black mustang and it has the old PCB. The 350z and the rx8 i bought both have the new one. It's a safe bet that you will get a new PCB in the new body styles. I have found one indicator of whether the cars have the new PCB or not without opening the box. Take a real good look at the antenna wire on the car. It's usually wrapped around the chassis in the package so it will take a good look to see what I'm saying. Take one of the antenna wires from an old car with you, you'll need it for referance. Now, here's the difference between the two. The new antenna wire is slightly thinner and more flexible. You can't test the flexability while it's in the package, but you can make out the differeence in thickness if you have an old wire or even a whole car to compare with. It's very slight, but you can see it.
Old 04-24-2003, 08:24 PM
ViperKid's Avatar
Redneck Drifter
won't the RS workers think you are loony when they catch you looking at all the zipzap boxes with a microscope?
Old 04-24-2003, 09:20 PM
TypeZer0's Avatar
TypeZer0 TypeZer0 is offline
0reZepyT
i bought a black mustang and it had the 2nd to latest pcb revision and it cranked out mad current to the motor, so much so that it went off the scale on my DMM which is limited to 200 mA. according to namuna's measurements, this is almost twice of what bitcharg's pump out. oops, forgot to mention it was a dual cell. but this mustang ran a 3.0 and 3.5 motor on single cell just fine. the pcb's in the rx8 and 350z is a newer revision that is supposed to fix the problem of the car slowing down on turns
Friends (Joey's Bag)
Rachel: Exactly! Unisex!
Old 04-24-2003, 10:34 PM
bdebde's Avatar
bdebde bdebde is offline
That's all folks
Don't count on the Civic or the black mustang having newer PCB's, the ones I got had the old PCB's. Rx8 or 350Z has newer pcb.
That's all folks!
Old 04-25-2003, 12:17 AM
Wide Open Throttle
weird...both my civic and black mustang pcbs are clearly different and handle the higher rpm motors much better than the purple PT and yellow mustang pcbs. the difference in speed was night and day.
Frequency Question Aethis Epoch RC1/43 4 11-11-2002 10:25 AM
Question, please awnser quickly. Supra-00 Bit Char-G / MicroSizers 17 10-25-2002 11:32 PM
Question about model putty... SPEED Bit Char-G Mods and Projects 1 09-28-2002 10:19 PM
Question about fullsize wheels set Mod..? SPEED QFM Racing Customer Support 5 09-25-2002 11:26 AM
