Old 04-16-2003, 06:44 PM
strider_mt2k
Originally posted by BabyKiller
dual steering spring umm isnt that to tough for the magnets?
It's purpose is to dampen the twitchiness of the steering for use with very high speed cars, ie: motor/gearset combos and/or multi-cell mods.
It doesn't prevent it from working, it just slows it down a little so the car has time to react.
The physics are interesting to think about at that scale.
It also helps keep the wheels centered of course, again for high speed cars, but I also found it usefull when doing larger or monster wheelsets too.
Old 04-16-2003, 08:07 PM
BabyKiller's Avatar
i should try that none of my duel cells go straight
+ (4.8v)
Old 04-16-2003, 11:10 PM
xatu's Avatar
xatu xatu is offline
they say im slooooow eh?
Dual steering springs is a MUST in dual cell cars. They wobble all over the place, and if you have the FS wheelset with the dual cell, I would highly recommend it. Because the steering spring has a hard time returning the wheels back to normal if they are full sized.
Old 04-17-2003, 04:24 AM
neo_m neo_m is offline
Controller
Have put a 3rd Battery on the conroler
Put A little LED in the controller so you know when its turnt on.
Taken the controler Criple Cap out
Changed the charging base strait to charge from batteries
Car
Put blue lights that turn on when you accelerate or reverse
Put Always on Leds (back and front) attached to chasis so you can use any shell
External Dual Cell
Internal Dual Cell
Put in a swich for Single and Double Cell
Droped the shell so the wheels sit nicer
replaced arial with Cat-5 cable
put in the 120mAh NiMH batteries
taken Crip Cap out of PCB Board
Ofcourse they aint on the same car
You know why?.... Because he can!
Old 04-17-2003, 04:29 AM
_NiTrOuS_'s Avatar
_NiTrOuS_ _NiTrOuS_ is offline
Mods, pshh, didn't do much really, I let my fried borrow my Bit, and he broke it, so I got a new one. No thanks to him, never lettin' him borrow anything again.
Double Car antenna (Winding around each other)
2.6
1.0 motor in the back for two reasons, 1: To use it when I want to run my car somewhere where I don't need speed, only control, like on a table, and 2: Looks like a little Nitrous bottle, das mi' nam'
The only REAL mod I did was the antenna, since the second antenna I wound around the original one is hard, I can put my car antenna up, and leave it there since it is now hard, therefore better range. Really gotta work on mine....
Maybe I can work on lowering mine...
~Ross
Old 04-17-2003, 06:35 AM
BabyKiller's Avatar
hmm ive removed the crip cap from my bcg board but i dont wanna open my ms board cause my friends 2 cars didnt have one in then and they broke there arials(cause there dumb ****s) there the noobs on here who rarely come on call fastfurious
+ (4.8v)
Old 04-17-2003, 06:56 AM
Buzzbait's Avatar
Buzzbait Buzzbait is offline
I just started modding my "main ride" a couple days ago. It's a Microsizer Pro with Toyota bB body. I've gone dual battery with the second bat riding on top of the pcb cover. I think I want to move it internally though, as I'm having some center of gravity issues with faster motors. I also raised the body to accomodate the bat in the bB, and constructed a dual cell charger.
I actually got in a Perfection LED kit for my bB, but there's no room for it with that second battery installed. The bat definitely has to go internal.
I'll hopefully pick up some paints this weekend, so I can start to work on the clear bB body that came with the car.
Old 04-17-2003, 12:12 PM
xatu's Avatar
Oh yes, I did the CAT 5 antenna mod, and attemped an internal antenna mod.
Old 04-17-2003, 01:21 PM
BabyKiller's Avatar
internal antenna please tell how you do that and where you found this
+ (4.8v)
Old 04-17-2003, 06:12 PM
xatu's Avatar
It's in the alternate antenna ideas thread. I think it's in Bit Science. All I did was put copper wire on the inside of the car and connnected it to the original antenna it gave about 3 extra feet, but it was weighing down the car, so I took it out.
Most Cost Effective Mods rggtm XMODS Parts and Hop-Ups 20 07-01-2004 12:12 AM
Mods For New-bes(and advanced) xmodsman Bit Char-G Mods and Projects 5 01-31-2004 08:18 AM
Look Here For Mods..... MicRoMaN Bit Char-G / MicroSizers 5 01-17-2003 03:51 PM
step by step how to for mods Twistid ZipZaps 2 12-27-2002 03:03 PM
Anyone Found any "Do It Yourself" Mods for ZipZaps? hawks10 Bit Char-G / MicroSizers 6 09-25-2002 11:41 AM
