04-13-2003, 07:43 PM
Steering Problems
I recently purchased an AutoModellista bcg set. With a r-spec motor, my car drifts to the right. Any ideas to correct this? I have tried adjusting the trim, but it is not enough to counter the torque.
04-13-2003, 07:44 PM
Blitzer Sonic
Double spring or bend the spring. Check any hairs in the wheels.
04-13-2003, 08:07 PM
What exactly do you mean by doubling or bending the spring? I have already cleared out all fibers from the front wheels.
04-13-2003, 10:35 PM
Yeah, I have the same trouble. All of my cars pull a little either left or right. I am having a heck of a time getting them to go completely straight. How do you do the double spring thing?? What other tricks can I try?? *help*
04-14-2003, 01:18 AM
Rice Me
well, usually cars will never go PERFECTLY straight... just cuz there's a lot of play involved in the steering mechanisms...
double steering springs WILL help, but will increase ur turning radius signigicantly... i've just learned to live with a slight curve in my bit's running...
04-14-2003, 04:05 PM
State Property
...have u tried takin the steerin bar out,and movin the adjust.bar all the way 2 one side,put the steerin arm back, and then tryin 2 adjust from there...
04-14-2003, 04:24 PM
Retarded Stunt Driver
look at your rear axle. do either of the wheels spin freely on the axle? if so theres your answer.
04-14-2003, 04:25 PM
Yeah, my wheels spin freely... oh well, I'll just live with the curve..
04-14-2003, 04:30 PM
go buy jbweld. a few drops on the axle will hold it solid. you will thank me.
jbweld can be purchased at homedepot or any hardware store for 3 or 4 bucks.
superglue might work in the meantime.
04-14-2003, 04:32 PM
Well, I guess that is to be expected. It's not like they're highly calibrated and precision tuned machines.  I have been taking little super fine hair-like strands of copper wire and looping them though the steering arm bracket to take up the extra room, thus, tightening it up a little. It seems to be working. It does not restrict the movement at all, but just makes the "slop" movement less noticable.
04-14-2003, 05:32 PM
My char-g also turns right a lot sharper than left? Any ways to correct this? How did yall get those icon things at the bottom of ur posts? I'm new to this forum thing...
04-14-2003, 06:52 PM
After about 20 or so posts, you go to your user-cp and use the "change avatar" option to put a picture there. It'll only let you do that after a certain amount of posts (I think 20), though.
04-14-2003, 07:39 PM
Do you mean like those lil pics that have like r-spec or something on it like this?
04-14-2003, 07:42 PM
04-14-2003, 08:19 PM
