Old 04-05-2003, 04:52 PM
InGaN's Avatar
InGaN InGaN is offline
GaN: Blue
Exclamation Mini Plane Question
Since I've already got a motorworks to make my plane, I need to know if this plane design would work. It's basically a ducted fan with wings. The tubes diameter in front will be about 2 inches (or less). I don't have places for the battery or electronics yet, but I can add those later.
< Plane construction paused>
Current Progress: 0%
Old 04-05-2003, 05:58 PM
strider_mt2k
Oh yes, but I'm afraid the Russians got there first:
MIG 15
Old 04-05-2003, 09:42 PM
xatu's Avatar
xatu xatu is offline
they say im slooooow eh?
Wow, you are actually going to build that? That's is gonna be really cool when it's done Good luck on the plane!
Oh yea, the idea would work, I have seen it alot of times before.
Old 04-06-2003, 02:09 PM
InGaN's Avatar
GaN: Blue
I am going to try to build that. I need to find something for the duct.
Old 04-06-2003, 02:47 PM
zclonedude's Avatar
zclonedude zclonedude is offline
i've no idea whats goinon
check this link out it might give you some ideas
http://www2.towerhobbies.com/cgi-bin...L=++&search=Go
its the smallest ducted fan i've seen.
Old 04-10-2003, 08:01 AM
Daisycutter's Avatar
Daisycutter Daisycutter is offline
Cuttin' up Daisy
BitPlane
InGaN,
A plane conversion sounds real simple doesn't it? It is .... assuming there is a Radio Shack near to you.Go to this website, www.ezonemag.com to the discussions and look under 'Indoor and micro' .You should see some bitplane stuff.
There is a link (under sticky: bitcharger index) to a site that shows you how to extend your Tx range up to 200' (Bitcharger secrets revealed), and lots of other stuff which is also applicable
to Bit cars.Check it out.
The forum setup is much like this one so browsing shouldn't be a problem.
Cheers.
Old 04-17-2003, 04:29 PM
InGaN's Avatar
GaN: Blue
Too bad I can't put any of this on it:
elwire
Old 04-18-2003, 11:52 PM
Cuttin' up Daisy
If this is your first plane, DF might not be the best option........
......anyways, someone made an Antonov 225 from six 3.8 DF motors.The four inboard were powered straight from the batteries, the two outboard were used for Megatech XEC diversion-type steering.I gtg now...I'll get back to you guys on this.
Noob Mini X question... id224299 Mini-X 2 02-28-2003 09:51 PM
Found mini R/C plane natedogg4674 Other Tiny RCs 4 12-11-2002 02:20 AM
Found mini r/c plane natedogg4674 ZipZaps 1 12-09-2002 08:49 AM
Found mini r/c plane natedogg4674 Bit Char-G / MicroSizers 1 12-09-2002 08:49 AM
