Old 03-27-2003, 03:04 PM
payaso payaso is offline
BIT PIMP
Originally posted by denden
OK , it's only a 18 window but , it is a mini ??
That looks great dude... When can I buy it? That's gonna look good next to spankys truck... Let me know
silla
Old 03-30-2003, 04:03 AM
Spanky's Avatar
Spanky Spanky is offline
Mr. Goop
ok. i just did the wheel mod and now the car is looking awesome. i will follow up with a how to, on the wheel mod, tomorow or the next day. i have to sort through all of the pics that i took... i also need to extend the charging base on my controller so that i can get the car to the charger. ride height has been almost trippled..
Old 03-30-2003, 04:04 AM
Spanky's Avatar
Mr. Goop
heres one pic
Old 03-30-2003, 04:17 AM
Spanky's Avatar
Mr. Goop
woah!! first test run and this thing flys!! gets good grip, and high top speed probably due to larger tires.. only problem is steering. i need stronger magnets, and a stronger steering spring.
Old 03-30-2003, 11:18 AM
midget_man1387's Avatar
midget_man1387 midget_man1387 is offline
midgetPimp
Send a message via AIM to midget_man1387
looks great
I have that super glue you see in that pic: IT SUX!
Old 03-30-2003, 01:16 PM
Spanky's Avatar
Mr. Goop
humm its working great for me... although i prefer Maxi-cure extra thick glue..
Old 03-30-2003, 01:20 PM
midgetPimp
It holds good, its just too liquidy, and takes a super long time to dry
Old 03-30-2003, 01:59 PM
Spanky's Avatar
Mr. Goop
humm must be something with the air. mine is liquidy, which is what i like about it. but mine drys instantly.. if you want to speed up drying. get some insta-set spray. they should have it at your local hobby store. if not tower hobbys has it.. i originally got it for my maxi-cure which is thicker and can fill gaps and stuff. once sprayed it the cure time is about 2-3 seconds.
Old 04-11-2003, 07:03 PM
viperdout's Avatar
It's Really Fast!
Spanky, the PT crewzer in the background of one of your pics! Where are those springs available?! They might be cool for my dual motor car!
Old 04-12-2003, 12:09 AM
Spanky's Avatar
Mr. Goop
they are to big for bits. your best bet for springs is to check out slot car springs.. there are several sizes. and they are not magnetic...
Old 04-28-2003, 12:24 AM
Spanky's Avatar
Mr. Goop
progress report:
part 1:
initial bodys were desigend for the raised chasis. and would still work great for a lifted bit. however the sides of the truck are to narrow to slide over the chassis...
part 2:
i chopped one of the resin bodys down the middle to make it wider so it would drop down on the chassis. everything was fitting perfect.. till i tried to mount on the tabs. the body is somehow magicly shorteded by 2mm... so the body will slide down to the mounting tabs now...
part 3:
Hammer Time!!! you guessed it, frustration set in with that resin body. so ive just poured another body and i now know what mods need to be made befor the next cast is made. slightly wideer and slightly longer...
thoughts:
i just hope i auctually get this finished befor tomy comes out with one... lol however my zip zap woody is coming along great. external detail is about 98% finished. mounting tabs are also about 85% finished. i think i am going to smooth out the wooden detail on the sides so that its easier to apply wood texture decals.
Project VIPER (DEAD) New project S12Driver XMODS Mods and Projects 3 04-08-2008 01:44 AM
project inject torpedo crazysk8r777 ZipZaps Mods and Projects 6 12-19-2005 02:33 PM
Project Bit-X Pietak440 Bit Char-G Mods and Projects 81 07-14-2005 02:15 AM
My First "Big" Project wasuri Bit Char-G Mods and Projects 2 11-30-2003 04:58 PM
Project Ideas sokalxballa XMODS Mods and Projects 0 11-23-2003 09:21 PM
