Old 03-20-2003, 05:33 PM
Timmz69
Wires
So I was thinking about power!!! I install my own stereo's systems and when your doing it you always want to use big thick power wires so you can get more power to your amps. So I was looking a minix's and saw this pic with some thickwires on this mini x. Would it help to use thick wires going from the batteries to the engine in a zipzap
Old 03-20-2003, 09:31 PM
sessiz10's Avatar
sessiz10 sessiz10 is offline
Told ya.
It's worth a try, I don't know how much if any it would help. Do it and keep us posted as to your results.
____________________
Meh.
Old 03-20-2003, 10:33 PM
xatu's Avatar
xatu xatu is offline
they say im slooooow eh?
Putting thicker wires would actually give more power to the motor?!?!?!?!?!
Old 03-20-2003, 11:57 PM
Gamma Burst Gamma Burst is offline
Hello all, I am an Electrical Engineer and I think I can shed some light on this subject. Thicker wires will lower the resistance of the connection but not by very much for this application. Resistance is a function of the length and the cross-sectional area (ie. thickness) of a wire. The shorter the wire the smaller the resistance. Also, the thicker the wire the smaller the resistance. The material also plays a role in the resistance. Copper wires are better than Aluminum, Gold is better than copper (kinda expensive though, eh). There is other stuff better than gold too, but considering cost a really good connection would be a thick copper wire made as short as possible.
However, I really don't think there is much to be gained here, but hey every little bit counts, eh.
Old 03-21-2003, 01:10 AM
dabigpig's Avatar
dabigpig dabigpig is offline
Ahhhh the good old DIY car audio installer
*** AMC Veteran ***
-- ^-_-^
Old 03-21-2003, 05:58 AM
Timmz69
I was thinking this would work best with a tricell mod...That way your getting every little bit of power u can....I always think bigger is better!!!
Old 03-25-2003, 08:58 PM
AZ_Legend's Avatar
AZ_Legend AZ_Legend is offline
It would be sweet if this mod worked keep us up to date on your progress.
Range and Wires aperson XMODS 2 01-20-2004 12:26 PM
Steering Wires Broken funkymonkey Bit Char-G / MicroSizers 6 01-14-2003 12:00 PM
Duel Cell Mod Wires takumi_drifto Bit Char-G / MicroSizers 16 12-31-2002 06:22 AM
Steering wires BLWNSTNG ZipZaps 0 11-03-2002 01:46 AM
