03-15-2003, 10:24 PM
isk8element too.
help needed with makin a bit helicopter
im thinkin about makin a bit helicopter but how would i make it turn  ? i know how ill me makin the helocopter body and i need to make it realy light so itll go in the air but turnin is hard. any help will be apreciated
2 BCG nissan fairladyz
2 MS sport honda s2000
1 LXX auto modellista booster
2 ZZ yellow &black honda civic
and 3 clones & a pcb.
03-15-2003, 10:45 PM
sounds like a great idea, but there is a lot of physics that go into a helicopter and I think it will be pretty hard to make from scratch...plus I think you'll have a hard time finding a small motor that is powerful enought o lift the whole assembly...
I believe turning on a helicopter is done with thel stabilizing propeller on the tail of the helicopter...good luck!
03-15-2003, 10:48 PM
Got Mini-z?
well u could probaly use one motor to spin the blade(3.8)...then 2 more motors one to move the helicopter blade from side to side and another to make it go forward by making the blade lean forward or backwards(1.0s)...the u might need another motor at the back with a smaller propeller...each time u turn the motor wopuld spin the other way(2.6)...4 motors 2 pbc boards a good chassi and body a modified controller and u got urself a helicopter..to many motors tho..might need alot of batterys too..preety possible tho
03-15-2003, 11:27 PM
isk8element too.
heres my proto type drawing. 3.8 for the top blade turbo motor for the side blade.the pcb is behind the chasis and batterie. but i think ill use 2 150mah batteries insted of one stock
03-16-2003, 05:56 AM
TinyRC Champion Racer
sweeeeet
ive been wondering when someone would bring a nit-helicopter to reality ! I
m pretty sure ure goint o need more than one 3.8 motor on the top, maybe you should thnk of a way to integrate 2 props on the top of its chasis, u should also use layman;s batteryss(for good weight distribution) the only problem is u would have to make battery holders for them and not solder them, and make a chrger.
seems like this could work ! im intrested in seeing the body of the a helicopter anyone is using!
03-16-2003, 10:26 AM
Poor Student
Ok, a helicopter would be interesting, but very hard. At the least you will need a full r/c system with micro components. To see what this guy did, go here. Pixel Helicopter
Fight Crime <--> Shoot Back
03-16-2003, 02:33 PM
isk8element too.
ok now im thinkin to try and get it in the air id put a 3.8 in the front then a 3.8 at the end of the chasis then another 3.8 at the end of the tail and either 2 150mah batts or 3 210mah batts
heres a pic of it
03-16-2003, 03:57 PM
Poor Student
lmao...
03-16-2003, 03:59 PM
isk8element too.
whats lmao mean i forgot?
03-16-2003, 04:30 PM
Poor Student
well it means laughing my ass off, but that was mean. i retract it.
03-16-2003, 04:33 PM
isk8element too.
well it looks kinda stupid but it would be cool if it works
03-16-2003, 04:50 PM
XMOD AUDI TT (my wish)
it wont work if u have only 2 motors and one pcb because the blades have to be able to change their angles, although u could refrain from that problem by making the motor spin faster and slower. It wont turn if u have 2 motors either itlls just be able to lift up. i think this project is too hard and i also dont think a 3.8 will be able to lift up so many motors and batterys.
03-16-2003, 08:30 PM
NSX Driver!
You would defentialy need the back prop to counteract the torq.
03-17-2003, 10:15 AM
well it will take a lot of luck and hard work but i think this has a lot better chance than a pod racer.
hahahaha
03-17-2003, 03:13 PM
Got Mini-z?
well is my idea of doing it pretty good? or is it just as lame as makeing that pod racer thingamagig
