Old 03-12-2003, 01:54 PM
freakanoid
help with my duel cells
ok i jus got my two cell 160nimh
they go quite fast but ive seen some peoples cars and they jus look great and they go soooo fast.
i try to charge them with this charger i made from a broken controller
but i am wondering if anyone know about that mod for your controller to make it charge non stop but can u still control your car with it.
please reply.
and what ways do u charge your duel cell cars
Old 03-12-2003, 02:15 PM
hogjowlz's Avatar
hogjowlz hogjowlz is offline
i use the 4aa charger that came with my boat.
you can also ad a 3rd battery to the controller but that takes longer to charge and will eat your batteries. but that will also double your range.
you need at least 3.4v to charge dual batts. my friend tested this on a scientific grade multimeter.
i like having a stand alone charger. but i dont have range issues either or i might change my mind.
Old 03-12-2003, 02:54 PM
MicRoMaN's Avatar
MicRoMaN MicRoMaN is offline
Microman to the rescue!!!
I think www.questformadness.com has a mod that you do to the controller to charge multiple cells.
-----My Mini R/C Site-----
Old 03-12-2003, 02:58 PM
hogjowlz's Avatar
i cant see how that would work since fresh aa's dont give off enough voltage.
Old 03-12-2003, 04:39 PM
ralliart's Avatar
ralliart ralliart is offline
i am po
Micro man, thats a good mod controller on qfm, but it only works for 2.4V charges...and if freakanoid has 3.4....then it wont charge properly...right?
Old 03-12-2003, 04:41 PM
hogjowlz's Avatar
no you need 3.4v in the charger to charge two 1.2v cells.
Old 03-12-2003, 04:44 PM
MicRoMaN's Avatar
Im not sure i just saw the mod a while back and posted lol.
Old 03-12-2003, 05:09 PM
hogjowlz's Avatar
my friend explained this to me mathematically yesteday but the math stuff ends up sounding like "blah blah waah wah" after a few mins but pretty much batteries or any electrical component has an internal resistance. you need (im pretty sure his meter said 3.4 it may have been 3.2) volts to overcome the internal resistance before it starts charging.
one advantage to this higher internal resistance is your car wont drain as quickly if you set it down for a few hours.
Old 03-12-2003, 05:12 PM
AUDI-TT's Avatar
AUDI-TT AUDI-TT is offline
XMOD AUDI TT (my wish)
is it bad to charge a stock battery with 3.7 volts? i could charge a duall with it too, but does it damage the 1 cell bit?
Old 03-12-2003, 05:14 PM
hogjowlz's Avatar
no just watch it. obviously a single cell will fill first and start getting hot first. if it does it should take off all its clothes.
heat = your battery is charged
heat = melted stuff or fire
Old 03-12-2003, 05:17 PM
AUDI-TT's Avatar
okok, so it wont damage the batt unless i keep it on for too long,
Old 03-13-2003, 11:30 AM
freakanoid
ok kool
im jus gonna go buy pack like u have hogjowltz
Old 03-13-2003, 11:34 AM
hogjowlz's Avatar
kennshop has the boats. which are worth 17bucks anyhow
Old 03-14-2003, 12:37 PM
SlowbutCourious's Avatar
State Property
...everyone here should listen to GODjowlz the name says it all..
2 740mah Lipo cells and charger, $7.50 Jazz32 Miscellaneous Discussion 5 01-17-2007 11:25 PM
Thin Film Solar Cells, inspired by azimov Jazz32 Miscellaneous Discussion 5 07-23-2006 12:15 AM
Sloow duel cell RobotGT Bit Char-G / MicroSizers 8 08-02-2003 09:01 AM
button cells for layman's mod TypeZer0 Bit Char-G / MicroSizers 3 06-18-2003 09:18 PM
Charging duel cell bits delaroca Bit Char-G Mods and Projects 4 12-08-2002 08:47 PM
