Old 11-23-2002, 09:06 PM
Chris's Avatar
Chris Chris is offline
Send a message via AIM to Chris
Dual battery mod will burn out motor?
I was just wondering, I just did a dual battery mod and I am afraid that the high voltage may burn out the motor, is this possible?
Old 11-27-2002, 09:50 PM
Acceptable_Risk Acceptable_Risk is offline
Not likely. The 2.4v you're going to be running isn't exactly high-voltage. The circuitry is easily safe up to 9v and the motors will take just about anything you can give them as long as you keep them cool enough.
Old 11-29-2002, 03:14 PM
datamonster datamonster is offline
I'm with stupid^
Send a message via AIM to datamonster
9 volts? now that's an idea!
Custom Body Kit, Rare Earth Magnet Mod, No Cripple Capacitor, 30 ft. Range
Old 02-20-2003, 02:24 PM
BillyP
Is there anything you can do to keep the motor cooler?
Old 02-20-2003, 02:38 PM
dabigpig's Avatar
dabigpig dabigpig is offline
the dual cell won't even make the battery get warm on my car perhaps 4 batts will but not 2
*** AMC Veteran ***
-- ^-_-^
Old 03-02-2003, 10:07 PM
RIGD1's Avatar
RIGD1 RIGD1 is offline
I just recently burned out my old Tomy 3.0 motor. It was already squeaking before the 2 cell mod, but the dual mod put the motor out of it's misery.
Old 03-04-2003, 02:49 PM
BillyP
Did your motor burn to death? My 3.0 gets pretty warm with only 1.5 volts from an "AA".
Hey, in the winter the temperature outside could drop well below freezing, where I live, anyway. I'm sure 9 volts couldn't burn out a motor then. If I'm not mistaken in thinking voltage is directly proportional to speed, a 4.0 motor with a 9 volt would be like a 30.0!
Old 03-04-2003, 05:04 PM
strider_mt2k
Running a motor with no load can burn it out and make it heat up more than loads it was designed to bear.
Under those loads the RPMs are lower and heat doesn't build up as fast.
Old 03-11-2003, 04:58 PM
Lord_Nick_D's Avatar
I cant stop modding
the ampage is so low and limited that there is no worry to the person with the AA powerd car the more amps buned it out faster Bits have current limiters in them
Old 03-12-2003, 07:17 PM
Dougboy's Avatar
Dougboy Dougboy is offline
climate control
it's not the motor that u should worry about. it's the battery itself. if anything in the curiuit goes wrong, the battery will start to fry and get really hot. they might even explode.
Drink Your Milk
ne1 know how to do a dual motor mod? isk8blind Bit Char-G / MicroSizers 8 01-13-2003 06:20 AM
dual battery mod no speed increase? delmonk Bit Char-G Mods and Projects 7 10-17-2002 12:10 AM
ZZ Dual Battery Mod Mattydiah ZipZaps 1 10-14-2002 10:58 AM
