Go Back   TinyRC.com > 1/24 and Smaller > Auldey / Radi-Can > Auldey (All)
Old 02-17-2003, 08:45 PM
scottyboyfun's Avatar
Im a cat, miow.
Relay Mod!!!!
What is the specs of the relays in the relay mod, ie, what have they got written on them?
Amps, etc, and how big are the relays in size?
Im gonna try n fit the mod to a taiyo, so I can wind the motor nice n low!
Ne1 ,what do you think? or know?
So what do u lot think?
Post it!
Old 02-17-2003, 09:00 PM
zclonedude's Avatar
zclonedude zclonedude is offline
i've no idea whats goinon
hope this helps
Old 02-17-2003, 09:02 PM
zclonedude's Avatar
heres a pic of the relays
Old 02-18-2003, 06:23 AM
Im a cat, miow.
Thanks 4 the help, just I think the taiyo/tyco has a different pcb, ne1 know how 2 install 2 this?
Im sure it wouldnt b 2 hard, bit of examining the circuit diagrams!
Post it!
Old 02-20-2003, 10:51 AM
mbartell mbartell is offline
so I re-wired it
what I did
I went to radio shack and got the relays there. they are 6volt 1 amp. 3 volts will not trip them. Match the relay with the power you are using- 2 cells is around 3 volts 4 cells is around 6 volts, depending on the battery. The relays were also around $3 a pop, and the lowest voltage they had was 6V. The one amp rating is for 120 VAC, or 12VDC, according to the side of the relay, so I figure I'm safe. I'd order them from the tinracers site, if I were doing it again, but anyway....
The PCB isn't that important, all you have to do is put the original leads to the motor to the signal post of the relay. Put a diode in between the signal post and the - on the relay, or you will get a VERY loud buzz. The diode allows the output to be - when you switch directions, and keeps it from shorting out when the output is + The motor leads are now just a signal to turn on the relay, and the relay puts full power to the motor, without going thru the pcb.
All you have to worry about is that the new motor leads from the relays go to the correct tab on the motor.
Other than that, you should be able to follow the wiring diagram for everything you need.
The only problem I've had is soldering wires to the contacts on the bottom of the relay. they have a tendancy to break off and leave you with a little nub that you can barely solder too. Some hot glue to keep the wires in position will help.
The only other problem I've had is trying to controll it. All the mini cooper (tyco fast gear) does is spin on one front wheel. On a grippy track, it'll go stright, but if you turn, the car rolls- for a long time. I'm using 4 1800ma AA batteries and a timiya torque tuned motor... I still haven't hooked up the super-duper (can't tremember the name) one yet.
Uhh, gee thanks Radio Shack.
Famous last words:
Hold my beer and watch this
Old 02-20-2003, 10:55 AM
Im a cat, miow.
Thanks! U answered it all 4 me!
I think tinracers were selling the relay kit quite cheaply, might have 2 consider importing!
Post it!
Old 03-02-2003, 06:11 PM
devedander devedander is offline
Tinracers got em for like $2 a piece, shipping is a bit much to buy just one but pick up some wheels or something to make it worth your while.
Why you should do the relay mod slotsurfer Auldey Parts and Hop-Ups 2 01-19-2003 06:31 PM
first relay mod slotsurfer Auldey (All) 2 01-12-2003 05:13 PM
NEW CONTROLLER MOD! Check it out.... mike_diaz19 Bit Char-G / MicroSizers 13 12-19-2002 12:02 AM
Reverse mod..while keeping reverse ZIZI ZipZaps 4 11-26-2002 05:06 PM
