Old 02-21-2003, 09:07 PM
wild03 wild03 is offline
Originally posted by ...
For 1 motor the price is $10.9?(shipping included) for 2 motors $16.52. If you are interested in ordering anything else from toyeast
BTW. Toyeast is also on Ebay, the motors are going for $4.50 + $3.50 shipping! I ordered me one just to run it by my homemade tach! The motors are also $4.50 at their site but I don't know how much they charge for shipping there!
NOW why can't Tiny compete with those prices? he is on the states so he can save on shipping!
Old 02-21-2003, 09:43 PM
sessiz10's Avatar
sessiz10 sessiz10 is offline
Told ya.
I don't think tiny is based in hong kong and i'm pretty sure toyeast gets a much better price seeing as they are a larger distributor. I would like to see tiny get some of the alloy rims in though
____________________
Meh.
Old 02-22-2003, 04:03 PM
Zephyranthes's Avatar
Blitzer Sonic
If the most a ZZ can handle is a 2.6, would there be any difference between a 3.8 and a 3.0 motor in it? The ZZ would putting out the maximum amount of power so both motors should be going at the same speed because they are getting the same amount of voltage.
Old 02-22-2003, 06:17 PM
sessiz10's Avatar
Told ya.
Actually the newer zips (revised boards) can handle alot more than a 2.6. I have no trouble spining a 3.0 or 3.8 (bitchar-g motors) in the newer cars. I just don't get the same speeds out of them, I'm thinking because of the contact on the motor and the size of the motor. This perfection motor out runs a bit with a 3.0 in it. The zips often times seem slower because they hold on to the road better than a bit with it's spinning rear. I don't know if it's the wheel base or the full size wheels front and back, but I've found that at higher speeds the zips handle worlds better.
Meh.
Old 02-23-2003, 12:56 AM
Well, If you put a motor with a higher rating than what the board can handle the board will not output the necessary amps to move it so a 3.8 might not even work! I will be using my 3.8 with a transistor switch so I don't have that problem, also like sessiz10
says newer boards are better so they might move a 3.8
Old 02-24-2003, 10:39 PM
barto barto is offline
Send a message via AIM to barto
How long do they work in stock Zz??
Old 02-25-2003, 09:45 AM
I'm not sure I understand the question?
Old 02-25-2003, 11:04 AM
Will they run a stock zz battery down fast.What is runtime with a stock zz?
ZipZaps:
Black Mustang Cobra:
Champange Honda Civic Coupe:
Antenna knot untie mod
Yellow Mustang Cobra body with no mods.
Old 02-25-2003, 01:03 PM
sessiz10's Avatar
Told ya.
I haven't really noticed much of a drop on runtime using this motor. I double charge my stock zip on the controller and I get a good 5 or 6 mins of runtime.
Meh.
Old 02-25-2003, 02:07 PM
Will double charging them decrease the life of the battery?
ZipZaps:
Old 02-25-2003, 09:20 PM
Blitzer Sonic
I don't think it will weaken the battery. The ZipZap battery is 100mah. That's double the MicroSizer one. They are both getting 3v charged to them for 45 seconds. 100 mah should be able to handle 2-3 charges.
Old 02-27-2003, 10:44 PM
CRUMB's Avatar
CRUMB CRUMB is offline
Send a message via AIM to CRUMB
ooooooooo
i've gotta get this motor
JuDgE nOt LeSt Ye Be JuDgEd YoUrSeLf
Old 02-27-2003, 10:46 PM
CRUMB's Avatar
is it really all that fast
Old 03-04-2003, 12:55 PM
Finally got the toyeast motor, It doesn't work as well on a "First Generation Zip" I had to push start the Zip to make it go! the Bit was much better and looked speedy, I'll have to put the motor thru the tach as soon as I get a chance!
Old 03-05-2003, 12:14 AM
Blitzer Sonic
I have a yellow OEM motor and it goes faster in my Zip than my 3.8 in my zip. It's the other way around though in a BCG. Don't know why, but this unknown motor is fast enough for my Zip to spin out. I was like wow because Zips are too slow to spin out.
Will perfection 3.8 and 150 mAH NiMH cell work with my zip zap? Please respond ASAP. ibbored ZipZaps 5 09-11-2003 12:25 PM
Zip Zaps in stock? Canadian Bit ZipZaps 24 05-29-2003 05:49 PM
perfection 3.8 with new zip zaps Blackgat ZipZaps 10 04-02-2003 08:17 PM
Stock Zip Zap 4 stock RX7 MS 49mhz Suntzu28 ZipZaps 4 01-16-2003 05:46 PM
will a BitChar-GMotors 3.8 Motor work in a stock zip zap??? jutte07 ZipZaps 10 12-25-2002 07:53 PM
