02-23-2003, 04:13 PM
XMOD AUDI TT (my wish)
Bit-limo???
a couple of days ago i saw someone who mad e a bit car with a case for an aaa battery and 3 bit batts. Well wouldnt it be really hype if someone could use 2 bit bodies and makea limo??? Someone should really try this out!!!
03-14-2003, 11:06 AM
The Master Of The Bit's
I would consider doing it but the problem is, how do you connect the two bodies together? you could super glue it, but then another thing is you would have another set of wheels on it, (the front of the first one, and the rear of the last one, inbetween are useless wheels, the drive gear for the first one, and the steering wheels for the back one.
Gotta be rollin on dubs dawg. . . .
03-14-2003, 11:07 AM
but then again. . . longer limos do have supporting wheels in them. . . oh my. . . i got it. . . . i am a genious. . . ill be back with some drawings maybe
03-14-2003, 11:26 AM
If you could make a limo bodywith small front edges and big enough body to fit the rear axel in it then that would work best. what i was thinking was to fit 2 bits back to back, with the steering wheels up front, and the drive wheels on only one of the cars with the larger drive wheels replaced with the smaller sized front wheels from somewhere. that way all wheels touch the ground, and when you turn, it can make that turn a little sharper due to the rear steering wheels, and the center drive wheels. that only permits its self when you have two cars with the same freq. you could easily get 2 speed sets and do this, and you would probably get a 2 or 3 battery system and get the motor with the most torque, and the 12:1 gear ratio. that will make your bitimo a little better with getting off. if anyone has any more ideas they could post, please do so.i would do it, but my controller is broken, but i am getting a car in the mail soon, and if i do fix my controller, i will do this, just go and get a speed set from my LHS.
(i know the drawing is bad, i did it in a few mins cuz if i didnt then i would lose my train of thought and it would be lost for ever. . . )
