Go Back   TinyRC.com > 1/64 and Smaller > Bit Char-G, MicroSizers, Z-Cars, Clones > Bit Science
Old 02-09-2003, 10:01 AM
Squishy's Avatar
Squishy Squishy is offline
Quack
lookin good. My thoughts; you should put the two bars in the front so that they start where the normal chargiing spot was and curl up to the front grill, so you could have the two contacts just stick up so you kind of ramp up on to them. not sure how to get down though. i be thinkin about it a post later. seeya
Old 02-09-2003, 02:26 PM
Dutch's Avatar
Dutch Dutch is offline
Sir Wrench a Lot
Send a message via Yahoo to Dutch
Now, a couple of thoughts
How about using gravity to help make better contact? Like build a small decline into the charging contacts.
Namuna,
Thanks for Idea.
I Just tried it and it works 90% better than being on a flat surface.
I'm still searching through my junk looking for more parts and ideas, Guess I'll have to scower the shelfs at work at see what goodies I can find (I work in a parts warehouse that sells parts for: All Terrain Forklifts, Skid-Steers, Man Lifts ect...)
PT Curiser, Honda Civic ,Porsche 911, Mustang (ZZs)
Honda S2000 MicroSizer
2 Old Motor Works 1 Style
2 Rally Racers
1 Cannonball Racer
1 Nakamichi N Racer
1 Micro RC (w/pistol grip remote)
If you can't fix it get a bigger hammer!!!
40 years old and still a kid (except I can drink beer)
Old 02-10-2003, 03:07 PM
Habbi Habbi is offline
Location: Furthest place from the bright center of the Universe
Just a thought..... on the bottom of the car in front of the charging tabs are two smaller tabs (actually the same ones they are just shown again) You could solder small soft wire under the car so if hangs down touching the track, then install the metal strips on the base of the track , or build a small box with a ramp and mount the gear inside. Put some guide rails and have the car stop over top to charge.
Of course some kind of tachion field emmitter would be better, but since I can't find any dilithium crystals....
* MS Skyline (Cat-5 Ant., Dual Cell, Bulb Headlights, Tomy 2.6) * MS Impreza * Tomy Fairlady Z Turbo (Tomy 2.6, Dual Cell) * H1 Hummer *
Old 02-10-2003, 05:34 PM
Dutch's Avatar
Sir Wrench a Lot
Habbi,
I though about that but there would be to many problems I think.
1. The wire hanging of the bottom would cause drag
2. If you back-up the wires could hang and fold backward
3. It would be hard to keep the wires from touching and shorting out the battery
My goal is to make this as easy as I can
1. NO soldering on the car or PCB.
2. Can be made from stuff around the house (or very little money).
3. Can be used on almost any car.
4. No permanent damage to the car.
I want to be able to make up 5 of 6 sets and then when my friends come over then can just attach the set to the car and race and when there done take it off.
2 Rally Racers
1 Cannonball Racer
1 Nakamichi N Racer
Old 02-11-2003, 05:39 PM
Squishy's Avatar
Quack
you could leave it as it is, but have it strap onto the car, and just have it snap onto the bottom to get contact with the normal charging points.
Old 02-17-2003, 07:50 PM
Nathan's Avatar
Nathan Nathan is offline
Bad Driver
Why don't you put a coil on the car somewhere, then a coil on the stand. Then you would have an inductie pickup. Oh, and a diode to keep the battery from discharging into the coil. The coils must be the same size, so try steering coils.
Old 02-19-2003, 02:20 PM
mattsx2005 mattsx2005 is offline
Lightbulb better idea
ok i havn't done this yet but i will soon and i don't have a cam either so i am gonna attach a pic i did in paint
matt
Old 02-20-2003, 04:30 PM
Squishy's Avatar
Quack
that looks pretty good, but looks like you will have clerance and contact probs.
Old 02-21-2003, 06:44 AM
BenCloned's Avatar
BenCloned BenCloned is offline
Clones Are Good
Try the method slot cars have been using for years: pick-up shoes and metal rails. You can raise the pick-up shoes so they don't contact the track, just the charging rails in the pits, or wherever you want them.
Shen Qi Wei:
Begun this clone war has.
- Yoda
Old 02-21-2003, 07:44 AM
Lightbulb yea
ben
that was basically my idea i juz used a piece of wood with holes instead of the track
matt
Old 02-23-2003, 12:24 PM
Steve's Avatar
Steve Steve is offline
zipped up tight!
I've been pondering this on for a while so I'm glad I found this thread. Has there been any progress on this project since the last post? My idea is this:
small rails on the track in a v-shape funnel the car into position, a blocker stops the car at the same point every time. Now, either electric or manually, charging posts raise from the track surface and make contact with the terminals on the car. When the charging posts are retracted, the blocker drops as well, allowing the car to leave the pits.
Old 02-23-2003, 12:36 PM
Dutch's Avatar
Sir Wrench a Lot
Steve,
I'm still tinkering with ideas and have tried a few things with little sucsess. I know you know how hard the car sits on the charger when you push in on. You have to make really soild contact on the charging points or you won't get a good charge. If I did do a manual thing like you suggest you would need seprate stations where the drivers are standing which would defet the whole idea of automatic. But I open to all ideas (keeps my brain from being idle)
2 Rally Racers
1 Cannonball Racer
1 Nakamichi N Racer
Old 02-23-2003, 12:47 PM
Talking hey
wat have you tried send pics
matt
Old 02-23-2003, 12:49 PM
phone
have u ever seen how a corless phone charges u could try something like that
matt
Old 02-23-2003, 05:40 PM
Steve's Avatar
zipped up tight!
[/quote][/b] If I did do a manual thing like you suggest you would need seprate stations where the drivers are standing which would defet the whole idea of automatic. But I open to all ideas (keeps my brain from being idle) [/b][/quote]
a while back, I pioneered the whole laser pointer lap timer project, and I was thinking perhaps, that I could use the same technology to trigger the charging mechanism. The car pulls over and blocks the light to a photo transistor, which triggers a short delay circuit, which then fires the slenoid and the charging contacts push up from the track and "jack" the car off the ground. Hopefully, gravity will be enough to make contact. I have a clone charging station that I put my 3cell Zip on and I just set it there and it works.
One advantage of the manual / remote switch would be variable charging times, as maybe you don't need a full charge to make it to the end of the race...a quick gas n go kind of thing.
I have no prototype yet, but here is a quick sketch. I've tried the rail funnel idea on my track and it was easy to hit and worked really well for lining the car up. The local Rat Shack didn't have any micro solenoids so that put a halt on things this weekend.
charge rate?????????? fisherman2000 ZipZaps Monster Truck 1 03-14-2006 10:27 PM
My LXX won't charge Nenox Bit Char-G / MicroSizers 3 11-30-2002 06:16 PM
charge time sipsap ZipZaps 5 11-25-2002 11:32 PM
