Old 02-17-2003, 11:16 PM
neo_m neo_m is offline
2 Things, BAD Range, NiMH Battery
Hi
Ok I got my Bit Char-G a few months ago.
Its a 27mhz so the rane is terrible (2 meters)
I opend the control to see if there was the criple capacitor.... and there wasnt one in there
So I had a look on the PCB board and there was one... so I removed it.... didnt make any diff to the range
So I finnaly got around to getting some new wire for the arial and OHHH MY GOD it worked... I got almost another meter
Is there anyother ways to get better range out of a 27mhz.
Now I also got a 120 NiMH battery.
Is there a special way your supoed to charg them becasue I still only get the same running time as the stock NiCD battery.
You know why?.... Because he can!
Old 02-17-2003, 11:17 PM
Just a little more arial makes it sooooo much better
Old 02-18-2003, 09:51 AM
Namuna's Avatar
Namuna Namuna is offline
Re: 2 Things, BAD Range, NiMH Battery
On the controller, use a telescopic antenna and/or modify to use another battery (for higher voltage)...This will strengthen the signal going to the car
Yes, it's a higher capacity therefore you have to charge it for longer...Since the standard controller is timed for 45 seconds, take the car off and put it right back on and do 2 or 3 consecutive charges.
Old 02-18-2003, 10:47 AM
scottyboyfun's Avatar
Im a cat, miow.
U know that range was very lame to start with, mayb the pot needs to be tuned?
So what do u lot think?
Post it!
Old 02-18-2003, 11:47 AM
hogjowlz's Avatar
hogjowlz hogjowlz is offline
every 27mhz car execpt one that ive seen had about 6-10foot
Old 02-18-2003, 02:42 PM
SlowbutCourious's Avatar
State Property
Originally posted by neo_m
Hi
...try 2 wires twisted together for antina worked good for my supra...
Old 02-18-2003, 02:55 PM
hogjowlz's Avatar
how do you guys run your cars with huge wires sticking out of the top? they are so topheavy like that. if you want your car to run right loosly coil the antenna and tape it over the heat sink. if you get crappy range after that go buy a cheap clone and transplant your pcb. thor racers and thunderbolts are totally compatable with tomy controllers.
Old 02-18-2003, 03:09 PM
Im a cat, miow.
Hogs, do you think that some thin enamelled copper wire would make a good aerial? Circled under the car body? u could get a real nice length under there!
Post it!
Old 02-18-2003, 03:21 PM
hogjowlz's Avatar
probably. i dont worry about that. i just stuff the stock one under the body so it doesnt rub any moving parts and i get 15foot.
Old 02-18-2003, 03:25 PM
Im a cat, miow.
Imagine getting 30 ft tho!
Ive got a whole reel of thin enamel wire, may as well try it, ill let u all know how it goes!
Post it!
Old 02-18-2003, 06:35 PM
about the pot... i did tune that but it just got worse... so thats out of it..
Just trying to find a telescopic antena to use.
There isnt many places in Adelaide Australia that i can think of that would sell the higher mAh battery from..... Hint Hint.. any Ausies know where to get some...
The origainal stock antena is still attached its just inside under the pcb board.
I think ill look for a higher freq car and use that one as a spare
Old 02-18-2003, 09:45 PM
dohc's Avatar
dohc dohc is offline
TinyRC Hacker
try cat-5 wires ;]
Old 02-19-2003, 02:36 AM
like i said i have already changed the wire and its the only thing that has improved the range
Old 02-19-2003, 02:10 PM
State Property
...2 wires is not that heavy lets have a race 35ft. does your car have that distance...not all my cars have 2wires just 1 with no range its not top heavy and not as heavy as 2 or3 cells.. my supra can go about 40 ft with 2 wires and no crip comp...if your in pittsburg pa than uour close...
