Old 02-17-2003, 10:41 AM
-v2oracle-
steering coil problem
when i turn my controller on the steering bar goes to one coil all the time, making my car turn hard left, and then when i turn to go right it goes straight, but when i turn my controller off it aligns fine again
can anyone help me?
Old 02-17-2003, 10:45 AM
hogjowlz's Avatar
hogjowlz hogjowlz is offline
Retarded Stunt Driver
probably your magnet. it may be the spring but i doubt it. if you crack your front end open, dont even look at the spring until you have ruled out everything else.
if you even slightly bend the spring, it will never work right again.
Old 02-17-2003, 02:47 PM
Namuna's Avatar
Namuna Namuna is offline
The steering coils have NO pulling power until juice is sent through it (thereby magnetising it).
If you're turning on the controller and it IMMEDIATELY pulls the magnet to the coil...Then I'd say you've got a sticky left or right button on the controller.
Check the controller out as well.
Old 02-17-2003, 04:18 PM
-v2oracle-
Thanks Namuna, i was thinking something along those lines too, i'll take a look see at the controller, i know for a fact my spring is fine, my magnet is fine and the coils arent getting power from anywhere else.....we'll see
Old 02-17-2003, 04:28 PM
hogjowlz's Avatar
if needed most old vcrs or stereos have the same buttons in them and aint that hard to replace. a solder sucker helps tho.
Old 02-17-2003, 05:14 PM
-v2oracle-
hopefully it'll just need a little cleaning........
Old 02-17-2003, 07:08 PM
scottyboyfun's Avatar
Im a cat, miow.
The steering wires definitely aren't touching newhere on the pcb?
The insulation may have came off on part and be shorting on the pcb, if if was ur controller, then surely the led would b lighting up.
MAKE SURE THE steering wires are not touching ne thing!
damn hairs!
So what do u lot think?
Post it!
Old 02-17-2003, 07:12 PM
Fourustwentius's Avatar
Fourustwentius Fourustwentius is offline
Help Me!
Yeah I had a prob like that, my insulation was melted off and crossing another wire.
At the bottom.
Steering problem rody XMODS 1 01-29-2007 10:18 AM
Really Bad Steering Problem, unlike any steering problem before it! 'Vette Nerd ZipZaps SE 11 07-19-2006 10:05 AM
Single/Multi coil steering columns cm961 Bit Char-G / MicroSizers 4 07-28-2003 10:59 PM
AH-HA!!! Solved uneven steering problem! mechanist ZipZaps 8 10-17-2002 09:24 PM
