Old 02-16-2003, 09:53 PM
Zer0 Zer0 is offline
dual cell possible prob
I Wired up the dual cell mod and for a charger I took three AA batteried and placed them in a line positve to negative one on top of the other when I connect the bit to the charger and press the gas the wheels spin but when I remove it it doesnt move ??? any help would be appreciated thanks
Old 02-16-2003, 10:28 PM
xatu's Avatar
xatu xatu is offline
they say im slooooow eh?
Hmm....maybe.....No, it would have to be wired correctly to get the tires to spin.... Is the sound of the motor higher? Or normal. It could be that your batteries aren't charging it right.... But I'm not sure
Old 02-17-2003, 03:11 AM
motor sounds higher, I took everything apart and brought it back to stock both batteried charge properly individually I had used two diiferent colored batteries from clones so I thought they might be different. I then took identical clones and used the same batteries wired it up and put it on to charge the engine roars while its charging but when I take it off it crawls then dies. Im lost here this is not making sense to me. Help Please
Old 02-17-2003, 03:58 AM
Solved
Ok I had to figure this out before I went to bed because it was kickign my @ss. I was following the direction on QFM site and guess what The diagrams are wrong. To correct the problem I I soldered a wire from the negative terminal in the car instead of the positive terminal and folded down the negative terminal and put the battery in normally with a wire sodered to the negative end of the terminal. I then closed it up and ran the wire from the negative terminal to the negative side of the second battery and then ran the negative end that was connected to the battery in the car to the positive side of the second battery and voila it worked and held a charge. while searching through the board I saw a few post where people had tried the mod off Quest for Madness with no success. here is a link from a site with the correct wiring diagrams for all that couldnt follow. hope this helps some of you http://foy.foy.com/minircmod/moddocs...attinstruc.htm
Zer0
Old 02-17-2003, 11:22 AM
xatu's Avatar
Those instructions from the link you gave was the one I used..... Easiest way to do it.
Old 02-17-2003, 09:48 PM
I agree. Now the only thing is to tighten the steering so it handles like my Zip.
which dual cell should i do, laymans, external, internal etc eman1 Bit Char-G / MicroSizers 11 09-02-2003 08:42 PM
Laymans dual cell vs. traditional dual cell Zephyranthes Bit Char-G Mods and Projects 6 02-18-2003 07:12 PM
Dual cell mod ( will 2 - 50 mah's achieve + speed?) Suntzu28 ZipZaps 7 01-11-2003 10:57 AM
Dual cell mod and discharge problem (cell reversal). kenny_dilger Bit Char-G / MicroSizers 1 12-17-2002 11:23 PM
