02-16-2003, 12:56 AM
Decreasing Speed - donuts when turning
I have a Nissan Gloria. did a dual cell mod for runtime not speed. It came with a 1.0 motor but that turned out to be a bum. Stopped working in 2 days. So now I put in my Panther motor but its a little too fast for my track. It just spins out when turning. Any ideas on decreasing speed other than buying new motors or something? Thanks. Here's the car by the way:
45 MHz Nissan Gloria Bit Char-g
Custom Tires (back)
Medium tires (front)
TOMY Bit Racer 2.6 Motor
02-16-2003, 02:46 AM
I did a dual cell mod, and it did the same thing....
Put two turn springs in one car... it worked perfectly for mine, so the wheels come back quicker. The car doesnt do as many doughnuts. It goes perfectly streight and.....it just works great :-) hope this helped
02-16-2003, 07:42 AM
so I have to do the spring suspension mod? Ill try that if possible..thanks
Custom Tires (back)
02-16-2003, 07:54 AM
V-tec aholic
no no no he didnt mean the spring suspension.what he meant was the thin return spring that is located on top of the stering magnet.he used two insted of just one.i also have a dual cell and did the same thing,it works so good i use this mod in all of my cars even the stock single cell bit's.
Drive it like ya stole it!!
49mhz/SKYLINE/2.6/STERING SPRING MOD/ANTENA MOD
27MHZ/SKYLINE/2.6/DUEL CELL MOD/ANTENA MOD/STERING SPRING MOD/WHEELY BAR MOD/CARBON FIBER HOOD LOOK.
02-16-2003, 05:08 PM
Evo VII
Go
put harder tires up front. and take a battery or somethign to add weight to slow it down
________
vapir oxygen vaporizer
02-16-2003, 08:35 PM
Not enough weight in the front. There are things you can do to contradict that (dual steeringsping mod) but I'd add some junk in the front trunk (make sure whatever the junk is that its not magnetic.
02-16-2003, 09:27 PM
yea I ment the return spring, sorry I didnt make it clearer.
Thanks Demon666 for clearing it up
02-16-2003, 09:35 PM
V-tec aholic
no problem dude.
02-17-2003, 03:53 AM
thanks..
Thanks guys...I have an extra steering spring So i guess I will add it there..Im just scared to open up the front incase it does something to the car..Had bad luck with them..I ripped up some old tires and put cuts in them and now theyre more grippy..just need to decrease speed  ill add some weight like snakebitracer said
Custom Tires (back)
02-17-2003, 11:58 AM
things ive done to keep my car from flipping.
suspension springs.
the more weight over the rear axle the better. this helps you from spinning out on slick floors.
i also taped a dime(which is 2.3 grams i think) over the rear end. but ive decided i like the speed better which leads to the most important thing needed to keep from flipping.
muh fah kin skill. really the more time you spend driving it instead of tryin to put "carbon fibre" stickers on your beast, the less you will have flipped over cuz you learned how to contain it.
02-17-2003, 09:22 PM
I Shall Return!
u ppl u seriously smart.... i mean im way outa my league, i just bout a microsizer and applied all that is listed bellow in signature, im mainly finished with looks, i took a blak skyline ad painted certain parts red as long with a exaust, im also beggining 2 customize my balh celica and red lancer, (their comin out great!!) your trik with the spring is a god send, i would get dizzy from watchin my car spin, and this was wit only 1 cell, however this will b taken care of shortly.....  ok i got a couple nooby questions first of all wats d easiest way 2 get an under glow light goin... i got 2 super bright leds and a chassis screamin 2 shine lol also microsizer says that their pro series has a booster button, wat dose this mean? are they 2.4V stok or r they slow and u must boost fer full speed???!?!?!?!? thnx u ppl rok
02-17-2003, 09:24 PM
I Shall Return!
im jk bout the podominant speed i wanted 2 sya that that is wat i want 2 do but this sping thing dose the wrk
02-18-2003, 01:23 AM
Epoch's R Bett'R
The "infinate speed potentiometer" mod is the only way to go if you want to fine-tune your speed. You just turn the little screw a little bit, and blam... it is easy to adjust up or down depending on your track slickness.
Just get the swp-11(i think) from allcorp.com and run it in line with the power wire to the motor. Don't do it like the mod states by running it in line with the power to the pcb. If you do this, you turn the speed down, and your steering goes down too.
I"m thinking about doing 2 of them. One to steering and one to the motor. Speed up steer down, speed down steer up.
ed...
