Go Back   TinyRC.com > 1/64 and Smaller > Digi Q > Digi Q
Old 02-14-2003, 10:03 PM
PTink's Avatar
PTink PTink is offline
i like pizza
Finally!!!!woooohoooo
I have finally ordered my AE86 digi Q with the special controller which will provide me with some drifting fun. I can't wait. If there are anythings you guys would recommend with care and cleaning or mods, just shout it out please
i will only list the cars that i use once in a while...
ferrari 360 MiniZ; tons of new parts
Integra Type-R Epoch; Stock
Wild CharG; stock, the lifting one
White Skyline microsizer; only factory upgrades, for good handling
Old 02-14-2003, 10:07 PM
Fourustwentius's Avatar
Fourustwentius Fourustwentius is offline
Help Me!
What do you mean, special controller? This will affect drifting?
At the bottom.
Old 02-14-2003, 10:47 PM
PTink's Avatar
i like pizza
I mean the Digi Propo Special. this will allow me to change the settings in the car so i will be able to drift the car with more control or something, keal, i hope you back me up on this one *crosses fingers*
Old 02-14-2003, 11:30 PM
Help Me!
I just got a nikko i racer mini cooper so no such luck? Maybe that controler would work, ya think I could control a digi-q with my nikko controler?
At the bottom.
Old 02-14-2003, 11:39 PM
djmr2 djmr2 is offline
Ummm NO
digi q != iracer
(not equal)
Old 02-14-2003, 11:58 PM
Help Me!
Must believe anything in print..............
At the bottom.
Old 02-15-2003, 04:34 AM
keal
Ptink,
Alrights! You're going to have so much fun with your Trueno and Propo Special controller. Like Adam pointed out in some of his posts, the gears in the Type R cars are enclosed, so you won't have to worry about cleaning out the carpet fuzz. As far as I know, you don't have to do any real maintenance on them. Just charge and play all day!
Learning to input the secret codes on the Special controller might be a little tricky the first time, so if you get stuck, just give a shout
Fourustwentius,
The I-racer isn't compatible with the DigiQs in any way, so you can't swap controllers. If you plan to buy a DigiQ, most of them come with a controller. The one Ptink is talking about, is a deluxe controller that you buy seperately. You can use it to fine-tune the car, like speed, turning, braking power... and there's code numbers you can type in that makes the car do some amazing tricks and stunts! Check out the DigiQ gallery and you'll see pictures of the controllers... the blue one with the computer screen is the deluxe Special controller
