02-12-2003, 04:13 PM
The best motor I've bought
ToyEast Perfection Motor
Holy cow this thing rocks. Even without the boost on my 350Z it goes fast, and with the boost it's just plain nuts.
02-12-2003, 04:16 PM
Retarded Stunt Driver
hows the torque?
02-12-2003, 04:25 PM
i got 2 of them motors yesterday
i put 1 in duel cell wild char g now it's as fast as a standard car with 2.2 motor
and faster than standard WCG when run on half speed using multi controler
i put 2nd motor in duel cell boost car
un boosted it's faster than standard car with 2.6 motor in & push the boost button & it's stupidly fast
02-12-2003, 04:29 PM
Originally posted by hogjowlz
hows the torque?
02-12-2003, 04:42 PM
Zhuge Liang - My Idol
the site says 35 newtons per meter for torque...is that good? is it more than r-spec?
02-12-2003, 04:43 PM
BIT PIMP
I would also like to know how the torque is compared to an R-Spec..
silla
02-12-2003, 06:19 PM
i am po
hmm...this might be like the most newb question,...but
whats the difference between the R-Spec and a 3.8???
02-12-2003, 06:20 PM
I have an R-spec, 2.2, 2.6, 3.0, 3.8, some other torque motor i bought from toyeast, and this one I just got has just as much torque as the torque motor and more than the others (have to check, but it seems like it). Its kinda hard when the wheels are spinning out so much :P.
02-12-2003, 07:03 PM
MICRO RC RAVEN#976
How much did 2 cost shipped to you. I have just gotten a R-spec motor and am awaiting a replacement for my first bitmod1 3.5 motor. It had some problems and is being replaced. From my experiences with both right now I definitely like the R-spec better.
02-12-2003, 11:14 PM
Rspec is a 3.8 with more torque. Its called the Rspec, its not the 3.8 rspec, rspec 3.8, or type-r 3.8. R-spec.
Formula 34 is like a 3.4 version of the R-spec. More torque than a regular 3.4.
Would YOU hit it?
02-13-2003, 02:05 PM
i am po
ahhh icic ok thx.
02-13-2003, 02:36 PM
Just kinda burned you...
Whats up with the motor's wierd endbell?
Does it increase voltage flow into the motor?
"I won't lose, no matter what, because the prize is a full tank of gas." Takumi
02-13-2003, 02:45 PM
the battery = yes
the motor i dont know about the new zipzaps with a dual battery im sure it would tho.
02-14-2003, 05:07 PM
NSX Driver!
i really wanted to know if the motor would work.
