Old 02-10-2003, 08:12 PM
chelboed's Avatar
chelboed chelboed is offline
Epoch's R Bett'R
Run 2 Frequencies on 1 std. controller!
Okay, I have a 27, 49, and 57mhz cars. I am tired of hauling around so many controllers, and I don't wanna buy a multi (which doesn't accomodate all of these frequencies anyway.
Here's my solution... Run as many frequency crystals on 1 contoller as you want with a switch to select between them. You could run all of the frezuencies out there if you get the right switches.
Old 02-10-2003, 08:16 PM
bamsk8er27 bamsk8er27 is offline
Send a message via AIM to bamsk8er27
man dude thats one of the best mods ive ever seen thats dope dude
Old 02-10-2003, 08:35 PM
isk8blind's Avatar
isk8element too.
dude sweet
dude thats sweet but what would be cooler id witha bit char-g booster car is to do that mod on it except with all four freq. and then buy the booster machine sets and you can use wich one when you want
Old 02-10-2003, 08:48 PM
chelboed's Avatar
Epoch's R Bett'R
Yeah, but I don't have enough room right now in my booster controller because I installed my alternate booster button mod on it. Check it out in the mods forum. I agree, though. It's totally possible and if you got a multi controller, and added the american frequencies, then you'd have everything plus the booster fctn.
ed
Old 02-11-2003, 05:10 PM
Squishy's Avatar
Squishy Squishy is offline
Quack
that is awsome man!
Old 02-12-2003, 08:19 PM
strider_mt2k
Thumbs up
Great mod!
Two thumbs up, way up!
Old 02-13-2003, 08:07 PM
strider_mt2k
With the proper rotary switch and the right crystals, you could do all available frequencies!
(I don't know how small it would be though)
Again, really great mod.
Old 02-13-2003, 11:43 PM
Nathan's Avatar
Nathan Nathan is offline
Bad Driver
You should just use two crystal sockets, one for the car and one on the controller.
Old 03-10-2003, 07:43 PM
BillyP
Can you use two freq's at once by soldering the crystals in parallel? I know it would only limit the number of people I could race. I broke my controller, but I have the crystal.
Old 03-11-2003, 07:48 AM
ph2t's Avatar
ph2t ph2t is offline
Chief Propeller Head
Excellent mod chelboed!
Just wanna clear up a few things though.
BillyP: you can't solder them in parallel, it just won't work. I think the low freq crystal will cancel out the higher freq one.
Nathan: the car isn't crystal controlled, but based on what is called a tuned circuit. This is determined buy R, L & C values in teh receiver stage of the circuit.
In fact I'm trying to design a new receiver circuit that can have multiple freq's.
Check it out
here at ausmicro.com
ph2t.
Old 03-12-2003, 03:16 AM
blownPT's Avatar
blownPT blownPT is offline
Send a message via AIM to blownPT
Is it possible to get those crystals somewhere? Rather than to just pull them from another controller?
It would be great to not have to buy whole controllers just to have other frequencies!
Also, I had a question, perhaps one could install a switch to reverse the forward/backward controll so that you could drive both zips and bits with them?
any input on that would be great!
-BlownPT
"If it's stock, it's just not good enough."
shaved rear door handles, rear rollpan, blown engine, shaved taillights.
Old 03-13-2003, 02:03 AM
frizzen frizzen is offline
Tool User
Your LHS should have the crystals.
And it would probably be possible to wire in a switch that inverts your forward and backward control. If I wasn't tired I'd start trying to figure it out now
Old 03-13-2003, 12:55 PM
blownPT's Avatar
local hardware store?
-BlownPT
Old 03-13-2003, 01:55 PM
payaso payaso is offline
BIT PIMP
LHS = Local Hobby Shop
silla
Old 03-13-2003, 02:17 PM
BillyP
You can get all the electronic stuff you'll ever need (almost) at this site, hence the name, All Electronics.
Controller trouble... Sleeping911 ZipZaps 0 06-24-2004 11:33 PM
Proportional Controller EMULATOR ph2t Bit Science 88 01-21-2004 04:12 PM
can these 6 frequencies run together? 2 bits, 1 MS and 3 booster clones? eman1 Bit Char-G / MicroSizers 8 08-06-2003 08:20 PM
Bullet type controller to run Tomy Bit? verbalkint Bit Char-G Mods and Projects 0 09-11-2002 10:27 PM
