Old 02-08-2003, 11:59 PM
BenCloned's Avatar
BenCloned BenCloned is offline
Clones Are Good
That is some great info! Now, if we could figure out how to measure the torque...
How about we move the decimal two places to the right on the MicroHP rating. It wouldn't change anything, except to make it sound more to scale.
Eg: MicroB 1.0: 1.50 MicroHP would read 150 MHP!
It just sounds more exciting.
Not that it matters!
Shen Qi Wei:
Begun this clone war has.
- Yoda
Old 02-09-2003, 12:23 PM
Namuna's Avatar
Namuna Namuna is offline
Hehe, that's not a bad idea BenCloned, and I believe there's a name for that...Nano (for 1/1,000,000th)
Hmmm, 150 NanoHP, that's got a nice ring to it!
I think I'm going to pickup an AC-to-VDC adapter from RadioShack and do the tests over again, this time with no PCB variations so we can get a more precise look at what the motors can do and what they need to do it.
Old 02-09-2003, 02:28 PM
kwikbb's Avatar
kwikbb kwikbb is offline
smoove operator
I'm gonna start callin' you Dexter lol... ' Uh oh Back to the Lab Again', 'Oh no Back to the Lab again'... the Mad scientist never sleeps!
Old 02-10-2003, 10:05 AM
Namuna's Avatar
Alright, I pretty up the numbers and put it all on the original post.
Enjoy.
Old 02-10-2003, 05:36 PM
BenCloned's Avatar
Clones Are Good
1 horsepower = 746 Watts
Watt = Voltage X Amperage
Tomy 1.0 = 1.50 MicroHP (30mA avg. draw)
Tomy 2.2 = 3.40 MicroHP (80mA avg. draw)
Tomy 2.6 = 3.49 MicroHP (30mA avg. draw) *efficient AND quick!*
TinyRC R-Spec = 4.01 MicroHP (105mA avg. draw)
TinyRC 3.8 = 3.92 MicroHP (80mA avg. draw)
ZipZaps Green (Performance) = 1.81 MicroHP (20mA avg. draw)
ZipZaps Red (Turbo) = 3.22 MicroHP (27mA avg. draw)
ZipZaps Yellow (NOS) = 2.65 MicroHP (33mA avg. draw)
Clone Pink (OEM ZipZaps) = 2.98 MicroHP 25mA avg draw)
Namuna- When you posted these #'s in the chart on your original post, you changed the values from this post. What happened?
Also, are you calculating wattage from the no-load figure or the loaded draw?
Shen Qi Wei:
- Yoda
Old 02-10-2003, 10:24 PM
Namuna's Avatar
Crap, you're right BenCloned...That's NanoHP for NO LOAD.
Alright, gotta update...Again.
Old 02-10-2003, 10:57 PM
Namuna's Avatar
It's late, I'm going to bed...Here's the updated chart...I'll fix it on the main page tomorrow.
Old 02-11-2003, 08:37 AM
BenCloned's Avatar
Clones Are Good
Thanks. For a moment there, I thought my math teacher had failed me.
Usually when a manufacturer lists the specs on an engine, they list peak power as a selling point. How about it, Tiny? Maybe another stat to add to the names of the motors you sell, since there was the whole motor naming contest - we may have something here.
Shen Qi Wei:
- Yoda
Old 02-14-2003, 12:33 PM
TypeZer0's Avatar
TypeZer0 TypeZer0 is offline
0reZepyT
just to clarify things, micro means onemillionth or 1/1,000,000 and nano means one-billionth or 1/1,000,000,000. i could post up a quick chart of those prefixes if anyone cares
Old 02-14-2003, 02:54 PM
Namuna's Avatar
Thanks for the correction, I've updated the pic on the original post.
Old 02-19-2003, 12:58 PM
hogjowlz's Avatar
hogjowlz hogjowlz is offline
namuna i think your pink clone motor is different than the one i have because there is now way that the tomy 2.6 gets more horsepower.
Old 02-20-2003, 07:36 PM
Jtskty Jtskty is offline
Master Debater
Send a message via AIM to Jtskty
More watts = more torque right? I want to know because I'm doing a project and I need a motor with a TON of torque. What would you get for that? I have a zip zap and it's getting a 2 cell mod if that matters.
now that I look at that chart it looks to me like the rspec has more torque than the every other motor. even the lower rpm ones. is that correct?
Sorry for being such a newbie but I really need to know.
Old 02-21-2003, 06:40 AM
BenCloned's Avatar
Clones Are Good
Your PCB has as much to do with usable torque as the motor does. Zips put out less current than Bits, and some clones deliver even more. The R-Spec is your best bet if your PCB can handle it. Early Zips can't without PCB mods.
Shen Qi Wei:
- Yoda
Old 02-21-2003, 06:47 AM
Master Debater
So if the pcb can handle it the rspec has the most torque out of all the motors tested? Even the 1.0?
vs.
Old 02-21-2003, 07:05 AM
BenCloned's Avatar
Clones Are Good
A 1.6 is supposed to have lots of torque, but Namuna didn't have one to add to his test. Of the motors tested, the R-Spec seems to draw the most juice, and should therefore have the most torque.
Shen Qi Wei:
- Yoda
Motor Power/RPM Tests Namuna Bit Science 76 08-17-2007 07:55 PM
1/4 mile speed tests Steve ZipZaps 3 02-22-2006 05:16 PM
speed tests!! esp rocker Bit Char-G / MicroSizers 7 06-23-2003 05:14 PM
Spring ant. and TV ant. range tests Azimov ZipZaps 3 05-05-2003 08:37 PM
