02-07-2003, 03:43 AM
SPEED IS GOOD
Some Shots of my Skyline......
Here's a few pics of my Somewhat modded skyline. I painted the Skyline body red with black tail light and hood for carbon fiber effect. I also Added a CAT 5 to the PCB. The knuckles and the strut bar (from a ZZ hop up set) were DYED red using RIT clothing dye. Any comments are appreciated! Thanks!
02-07-2003, 03:44 AM
SPEED IS GOOD
pic2
02-07-2003, 03:45 AM
SPEED IS GOOD
pic3
SPEED IS GOOD
Pic 4
Forgot to add i added an "intercooler" effect with staples on the body (a bit hard to see in the first pic but it's there)
02-07-2003, 03:47 AM
SPEED IS GOOD
last pic
If you hadn't noticed my bit is sportin' a red/black colo scheme. I've even redone all the PCB wires to red and black (because the stock wires broke  )
02-07-2003, 11:24 AM
.pylonspeed.
Funky. I dig the dyed suspension. I was randomly coloring the front suspension on a cheap clone blue with a marker, but it quickly rubbed off.
02-07-2003, 12:51 PM
Bit Baron!
koo. where's ya get the rear rims?
Black Honda Civic Coupe Zip Zap
-Sport Tires
-Turbo Gears
-Green Motor
-Chrome Rims
02-19-2003, 03:04 AM
SPEED IS GOOD
thanks for the comments the rear wheels are from ZZ's. I used a ZZ axle in the back, i'm going to have a full set of ZZ rims when i find a drill bit small enough for the axle pin hole.
02-19-2003, 09:03 AM
Garage Rocker
You can just swap the steering knuckes. Ther will be a little bit of extra slop in the suspension, but if you swap the sway bar it's fine. You can also swap the wheels on the knuckles, by warming the pin with a soldering iron, I used a 15 watt one, just long enough to soften the plastic, but not so long that you melt it. Then the pins pull out fairly easy, and go back in snug too.
I don't see why you'd need a drill unless your planning to drill out the rear wheel to use on the front, in which case a drill would be overkil, and you'll just have problems. All you need is a drill bit, and somekind of homemade handle to attach it to, to make a hand drill. That way you have control over what your doing
03-12-2003, 06:55 PM
SPEED IS GOOD
Yeah thanks for the tip. I don't have a ZZ right now, and i already have 6 ZZ axles i got from the tune up kits. I figure i just make a hole through the ZZ axle wheels and put them up front. The Knuckles i use are from a clone and the pins were not knarled so i can take them off fairly easily.
03-12-2003, 07:49 PM
Chunk
Nice idea with the staples. I'm going to have to try that. Nice looking Skyline btw.
A religious war is like
children fighting over
who has the strongest
imaginary friend.
03-15-2003, 10:40 PM
SPEED IS GOOD
Thanks!
I'm currently working on a body kit for it out of Note cards. Just a few ground effects nothing to insane. I'm also looking for a nice Spoiler replacement. Any suggestions???
03-15-2003, 11:10 PM
Got Mini-z?
for a replacement spolier u could use lexan...thats wat i used..heres a pic of it
03-15-2003, 11:11 PM
Got Mini-z?
heres another veiw of it
03-16-2003, 12:39 AM
SPEED IS GOOD
Thanks for the tip and nice skyline by the way!
