Old 02-05-2003, 09:24 AM
T_T_52
I'm going to try this with a car. but still I'll charge it and run it in the sun. The car would only have a long runtime because my solarcell will go to the internal cell. It would be a long run car. I just need to see ho fast of a motor I could install.
Old 02-05-2003, 08:49 PM
2fst4u's Avatar
2fst4u 2fst4u is offline
big gulps, eh?
Send a message via AIM to 2fst4u
is there a way to by-pass a battery all together and wire the solar panel directly to the battery tabs?
Old 02-05-2003, 08:53 PM
strakka's Avatar
strakka strakka is offline
AA member
Send a message via ICQ to strakka Send a message via AIM to strakka Send a message via Yahoo to strakka
i have a panasonic bp-376634 solar panel. the thing cranks out 5.5v, 30mA. would this work? i really need help on this i wired my panels directly onto the circut port and it didnt work can any1 tell me where i went wrong? and how to do this?
Thnxs
Old 02-06-2003, 07:13 AM
funkymonkey funkymonkey is offline
Hmm, I like the idea of a Solar Bus. Just use the panel to charge the battery - that way, it should be able to either charge the bit battery, or at the very least supply power for the RX board when it's not being used, keeping the battery from running down between charges.
The guy with the Solar panels, I think you'd need to wire the SP directly onto the Bit Battery, though 5.5V is pretty high for a 1.2V battery. Ok, you probably wouldnt fry it cos the power from an small SP is so low, so it prolly wont do much harm to try.
I doubt the panel will have enough power to run the motor, but it will hopefully increase run time
Battery geek.
Old 05-26-2003, 03:35 AM
Azimov's Avatar
Azimov Azimov is offline
I process, therefore I am
solar powerd bit racer Spanky Bit Char-G / MicroSizers 14 05-28-2003 05:59 PM
bit racer 2.6 vs. bit char-g 2.6...differences? spikeymike218 Bit Char-G Parts and Hop-Ups 2 12-20-2002 04:13 PM
Speed racer mod bit charge Crystal Method Bit Char-G / MicroSizers 5 11-24-2002 10:55 AM
Cheapest place to get Bit Racer tires? Ghost of Akina Bit Char-G Parts and Hop-Ups 7 11-11-2002 04:18 PM
Bit Char-G or Bit Racer tires? Bootylactin Bit Char-G / MicroSizers 4 08-24-2002 03:17 PM
