Old 02-05-2003, 08:16 PM
hogjowlz's Avatar
hogjowlz hogjowlz is offline
2 battery stability
after doing two battery cars i had one major problem. controlling all that power. heres what i have done to make my ride handle better.
suspension springs. those stabilizer bars just dont cut it.
modified rear axle. i dremelled out the axle holder and slipped a qtip tube over the axle and epoxied it in place to tighter specs than stock.
more weight over the rear axle. this is still work in progress but i have a dime taped on top of the body/2nd battery and this really helps it go strait. it loses a little bit of acceleration off the line but is neglegable with two batteries and a good motor and keeps the rear end from slipping around on slick surfaces.
the body looks fairly crude at the moment but my next project is to incorporate all the extra weight into the shape of a new body then she will be painted up and ready to bling.
Old 02-05-2003, 10:05 PM
batesjm's Avatar
batesjm batesjm is offline
My Alter Ego Is Retarded
Im having the same problem, Im going to try a dually rear end. ie 2 tires on each side. Ill post pics later.
I like Pie
Old 02-05-2003, 10:33 PM
bdebde's Avatar
bdebde bdebde is offline
That's all folks
WTF is a qtip tube?
That's all folks!
Old 02-06-2003, 08:04 AM
hogjowlz's Avatar
Originally posted by bdebde
WTF is a qtip tube?
look up qtip on google or in a grocery store
figure it out.
dualies aint needed. i may still put on thicker tires but i dont think its needed anymore. weight placement and springs seems to be the most critical. did i mention that it rides wheelies?
Old 02-06-2003, 08:31 AM
kwikbb's Avatar
kwikbb kwikbb is offline
smoove operator
Hell yeah! Now your talkin'... you need to hook that ride up with a
'Bit Dra-g Axel'! *scroll up for pics
kwikbb edit: Forgot to mention the pullback tires are Super Sticky and soft.
Old 02-07-2003, 12:25 PM
hogjowlz's Avatar
ya ill get those when the hype wears off a little and i can buy them from within the us.
Old 02-07-2003, 07:12 PM
scottyboyfun's Avatar
Im a cat, miow.
Sanding down the tyres using VERY FINE sandpaper while the wheels are moving works wonders.
I used the edge of the dremel cutting disc to do mine, just so the sheen is taken off. (the brown/red disc, the one which breaks if u breathe on it too hard! lol)
My 3 cell modified length drag panther used 2 go in circles, now it goes straight!
I coundn't believe the difference!
DOWN to basics-
TRACTION is important.
So what do u lot think?
Post it!
Old 02-07-2003, 10:15 PM
chelboed's Avatar
chelboed chelboed is offline
Epoch's R Bett'R
Hey hawg..whatever,
I moved my battery a bit forward (just in front of the rear axle).
I had no problem with hooking up, or with wheelies. (unless you do it on purpose).
Also, try the Toyota bB body. You can fit the second cell directly under the cab right between the front and rear axles.
Works for me.
ed.
Old 02-07-2003, 10:27 PM
hogjowlz's Avatar
bbs are ugly. i got mine running pretty good at the moment. im gona redo my rear axle with a thinner tube.
Increase short battery life! underglow ZipZaps SE 1 09-17-2005 06:51 PM
