how can u even do that i tried it once and the spring absolutely rejects the positive end. i tried forcing it a bit but gave up after a while lol how did u manage? i'm pretty sure you can maybe unhook the positive end from the spring if that's what's causing it to lock itself on to it.
oo you mean you screwed it back too tight? err that's a problem use a mini power drill or put some glue on the screwdriver to make it stick to the screw. i stripped 3 of my screws once so i had to do that and it worked...dunno if it'll help your situation tho
i think he's talking about the battery cap on the controller. from what i remember, it had this weird lil holes for the negative end. if you put in the positive end accidentally, it'll lock cuz the spring on the inside will shove the positive nub thing into the hole and then ur screwed
