Old 02-02-2003, 01:43 PM
Impreza WR reX's Avatar
Impreza WR reX Impreza WR reX is offline
<(- -)> <- Yoda
weight reduction
Hey, I went a little crazy with my Xacto knife and my bit last night...here's the results. I'm pretty pleased actually- I use ZZ gears and fullsize ZZ wheels with a clone motor, everything else is stock. This thing goes fast enough to flip when I turn! I can't wait until I can strap my R-Spec in there when it comes. Also, I rerouted the antenna so it goes through the back and I untied the knot (it's kinda hard to see b/c I have a white antenna), this gives a big increase in range.
wooo hooo!
Old 02-02-2003, 01:47 PM
<(- -)> <- Yoda
forgot the pic...
I guess you could say that I removed the "tub" from the tub chassis
wooo hooo!
Old 02-02-2003, 01:59 PM
<(- -)> <- Yoda
here's the bottom
The only problem is you have to make sure that the wires are tucked in, like I didn't in this picture...
wooo hooo!
Old 02-02-2003, 02:00 PM
BOme}{_2k5 BOme}{_2k5 is offline
Send a message via AIM to BOme}{_2k5
won't it break in half?
Old 02-02-2003, 02:17 PM
Squishy's Avatar
Squishy Squishy is offline
Quack
i agree with BOME, you went just a little more than a little crazy.
Old 02-02-2003, 02:22 PM
<(- -)> <- Yoda
actually, the pastic as enough flex where it's strong enough that it doesn't break. Just make sure that you don't step on it or something.
Also, the clear cover on the top keeps it strong when crashed becuase it takes all the pressure
wooo hooo!
Old 02-02-2003, 02:45 PM
<(- -)> <- Yoda
I just noticed that the car seems to be more balanced as well. I can drive it off dropes about a foot high and it lands flat on its wheels..
wooo hooo!
Old 02-02-2003, 02:49 PM
try reducing the weight even more lol it would be a racing piece of paper ish thing.. haha iono
Old 02-02-2003, 03:38 PM
<(- -)> <- Yoda
lol, maybe I'll make a chassis out of styrofoam...that would be intersting
wooo hooo!
Old 02-02-2003, 05:24 PM
Canadian Bit's Avatar
Canadian Bit Canadian Bit is offline
You can't beat it.
Or if you can afford it......... carbon fibre! Put two 150MAH cells in, and watch it fly!
My Garage: One Lamborghini Jota, Murceilago, Diablo, and a Countach.
One Ferrari Enzo.
One Porsche 911 GT2s, and 1 911 Turbo.
One Mercedes SL600.
1 Mitsubishi Eclipse.
Two 95' Mazda RX7s.
And 4 dozen Toyota Supras, 6 Skylines, and a Hino Blue Ribbon Bus from the Keisei Line.
Old 02-02-2003, 07:10 PM
Dorifto! Dorifto! is offline
Drift!
Can you tell much of a diference with the reduced weight as far as handling and acceleration is concerned?
All your base are belong to us!
Old 02-02-2003, 07:47 PM
<(- -)> <- Yoda
Yea, it turns a little tighter b/c there's less weight to pull it out and as far as acceleration, it should be faster with less wieght. I can't really tell because it does a burnout every time I press forward (not enough traction).
wooo hooo!
Old 02-02-2003, 07:52 PM
Drift!
sweet, I should try that to my car.
Old 02-03-2003, 12:01 AM
i kno!!!!!!!!!! put rear tomy pullback wheels on that baby! those wheels are wide and have heeella traction!
Old 02-03-2003, 12:55 AM
Happy_Boy's Avatar
Happy_Boy Happy_Boy is offline
Eat my Shorts
Send a message via ICQ to Happy_Boy
That. is. some. crazy. moding.
too risky for me...
G0_oD Day.
Bits = AM Set(R34,R32,Supra,Rx-7 shells)
3.0 motor,black rims
Body Weight Steve ZipZaps Mods and Projects 3 02-19-2006 08:56 AM
Crazy weight reduction Thread Reaper XMODS Mods and Projects 7 01-10-2005 10:05 PM
weight reduction allahsone XMODS Mods and Projects 0 03-10-2004 02:05 AM
Initial D is addictive zombiebaby Bit Char-G / MicroSizers 96 07-20-2003 01:31 AM
weight reduction.....worth it? MTL Bit Char-G Mods and Projects 6 09-08-2002 11:12 PM
