01-30-2003, 08:45 PM
Modder-Eater
ShAzBoT!!! SoLdEr MaN HaS BeAt Me
I just got a solder gun, solder and a black mustange today and decided to try and do the pcb mod and jump the resistors (think that's the correct terminology) on my older car. Oh boy did it go bad. My inaccuracy caused most of the nearby resistors to fall off, and I think I burned the PCB itself....oh crapomingo. At least I have the mustang. And before that PCB experiment, I was able to solder back on the antenna. And at least now I have a battery for dual batting.
01-30-2003, 08:52 PM
how many watts is your soldering gun?
***  AMC Veteran  ***
-- ^-_-^
01-31-2003, 03:26 PM
Modder-Eater
I believe a 15, not sure if its burned, but if turning black is any clue lol well there u go
01-31-2003, 09:08 PM
you said soldering gun is this one that u push the trigger or is it just shapped like a gun with an on off or even no switch? well im thinking that you had a soldering gun with a trigger and thats wrong for your application if u goto menard they have soldering IRONS for 4 bucks and radio shack has them for 7 pick one up and use those
02-01-2003, 02:51 PM
funk master flex
soldering irons are 4-7 dollars? woah?
02-01-2003, 02:55 PM
that seems awfully underpowered for a gun mine is a two stage gun on low it is 240W and on high it is 325W
***  AMC Veteran  ***
-- ^-_-^
02-01-2003, 06:04 PM
funk master flex
ok i didnt know solder irons were so cheap, i guess ill pick one up.. but question, how many watts should a solder iron have for using them on zips?
