Old 01-30-2003, 08:54 PM
mini rc man's Avatar
mini rc man mini rc man is offline
htf?
htf do u take out the damn wheel pins in front
AHHHHHHHHHHHHHH
IM MAD THIS IS MIND BOGGLING PLAESE HELP!!!!!!!!!!
Old 01-30-2003, 08:58 PM
Happy_Boy's Avatar
Happy_Boy Happy_Boy is offline
Eat my Shorts
Send a message via ICQ to Happy_Boy
Lol.....i need to know how to take out the back ones AND the front ones...
i'm so new to this stuf...lol
G0_oD Day.
Bits = AM Set(R34,R32,Supra,Rx-7 shells)
3.0 motor,black rims
Old 01-30-2003, 09:04 PM
back ones are EZ EZ EZ just put pliers on one side and the other wheel pull out with your teeth then to the same to the other side and the gear comes off easy jusst keep twisting side to side and pull
Old 01-30-2003, 09:10 PM
Dorifto! Dorifto! is offline
Drift!
How to take out the front pins: first, dissasemble the front end of your car. Second, lay one of the front wheel assemblies on something with a hole through it (I laid mine on the head of a set of pliers that were slightly open). Third, tap the pin out from the back with a small nail or something about the same size as the diameter of the pin and your good to go. Good luck I hope this helps.
All your base are belong to us!
Old 01-31-2003, 12:56 AM
frizzen frizzen is offline
Tool User
or VERY CAREFULLY take a pair of diagonal-cut pliers, lightly grasp the head of the axle pin, while holding the nuckle in your fingers. You should be able to gently pull it out with a little rotating.
but make sure you don't cut through the head of the pin!
Old 01-31-2003, 05:29 PM
thx
