Old 01-25-2003, 05:28 PM
Vroomvroom's Avatar
Vroomvroom Vroomvroom is offline
Send a message via Yahoo to Vroomvroom
Exclamation S-01
Just want to mess around with the s-01 gear set and see what I can do with it. anyone know where to pick one up, plz let me know~
Old 01-29-2003, 08:46 AM
Lowtrac's Avatar
Lowtrac Lowtrac is offline
My spoon is too big
Probably the cheapest way is to go pick up some KIT racing cars that have the same ratios as the S-01 set. The gears in the set are 3.43:1, 3.95:1, and 4:57:1 if I'm not mistaken. All of them are higher ratios than the "stock" 9.86:1 in the bits. You'll get higher speeds with the tradeoff of slower acceleration. I found the set HERE . You may be able to find them cheaper though. I could find any on Toy East.
Old 01-29-2003, 04:09 PM
SPEED's Avatar
SPEED SPEED is offline
SPEED IS GOOD
Well those are Bit racer gear sets. They'll have to be modded to fit. I've also heard from other places that some motors have a hard time turning the gears because of the gearing and really lags in take offs. I'm with lowtrac, get the ZZ gear set.
Old 01-30-2003, 06:59 PM
QFM Racing's Avatar
QFM Racing QFM Racing is offline
Moderator - Modifier
http://QuestForMadness.com
If you have a dual cell 2.4v modded Bit, then torque wont be a problem. My 2.4v bit is running the blue bitracer gears with an 8T pinion and its takeoff is fine. Not as quick off the line as a 6T with the stock gearing but decent. Top end kicks.
QFM Racing's Custom Bit Modifieds (The Bit How-To Page)
http://questformadness.com
Old 01-30-2003, 08:07 PM
Vroomvroom's Avatar
Now add the boost effect on new cars into this equation , which I will experiemnt with when I get these gears, and what happens, can a dually with a r-spec or equal type motor pull a decent start, Im not talking just not having to push it, I mean does it get up and go in a good enough way to hav e use of these gear ratios for speed. I am asking all of you as well as myself and hope to find out someday) So far a 3.8 motor in a boost with light green gears gets up and goes fine on regular power. Boost its as good as your motor. This is with just a single nimh battery atm.
