Old 01-28-2003, 12:35 AM
payaso payaso is offline
BIT PIMP
Originally posted by binaryterror
Anodized Aluminum is still conductive on the surface! The best bet to make aluminum less conductive is through coating it with a non conductive material (i.e. plastic, rubber, powder coating).
My thoughts exactly... Powder coating would be the best bet...
silla
Old 01-28-2003, 12:42 AM
shocon2k
Carbon fiber would be really hard to work with and custom form unless you have access to single sheets of carbon weave and a means to laminate them over a mold.
Old 01-28-2003, 12:43 AM
Silentbob343 Silentbob343 is offline
"by Jim Bowes
Based on the number of companies selling, and people looking for, anodizing services for their gun's aluminum bodies and parts, I wanted to provide this info to the paintballing community. I first came across the process in Super Chevy magazine, in an article about anodizing your own parts and brackets, for a custom touch on your hot rod. (* Original article by Bruce Hampson.) Often anodizing is considered and/or presented as a difficult and expensive procedure. As it turns out, it really isn't that hard or that pricey.
Supplies Needed:
The first thing to do is to get the following things together: First on the list is the most expensive item: a 6 to 12 volt battery charger. This item is what might make this too expensive for some paintballers. I (and most other hot rodders) already have one, for my car. If you don-t, then you will need to pick one up. They run from $45.00 to $110.00 depending on model, functions, etc. While it may seem like a lot, it does have other uses. (You could charge a battery, for example.) =) The next item, though not that expensive, will take some effort to find: battery electrolyte, a.k.a. sulfuric acid. This should be available at a battery wholesaler for about $2.00/gal. To make the negative ground, you will need some aluminum ground wire and aluminum-foil. The wire can be found at an electronics store for about $35/spool, and you should have the foil in the kitchen. If you happen to be out of foil, you can pick up some more at the store when you go to buy the last item for this project.
No super-special chemicals or solutions necessary to make the colors; just plain-old fabric dye. (Something like Rit dye, for about $5.00.) Rit offers something like 30-40 different colors, so you have quite a number of choices for what color you want your parts to be. An optional item is nitric acid: about $25.00/2.5 L. (This is used to clean parts prior to anodizing, but there are some cheaper alternatives. See end notes.) This is available at chemical supply stores. Should you not be able to find any, you can try to get on the good side of the high school science teacher. He may help you out since you only need a few ounces.
Safety Precautions:
There are a few precautions I want to go over to help keep you from blowing up the house or trashing the garage. First of all, do not mix or store your anodizing solution in a glass container. Something could happen to make it break, and most households are not equipped to deal with that kind of spill. You also don-t want to knock over the container, so a stable, rubber bucket makes a good choice. You will also need to be certain that the part you want to color will fit in the container without sticking out of the solution, and without touching the negative ground in the bottom of the container. Any acid that you don't use, keep in what it came in, or an old plastic bottle, like a bleach bottle. You can also store your used solution this way for doing more parts later. (Make sure that there is absolutely no bleach left in the bottle. Acid and bleach make chlorine gas. Very bad. Don't breath. Poisonous.) Safety also applies to the nitric acid, but in a different way. It is imperative that you label and keep track of this stuff, as it is a stronger acid than sulfuric, and more dangerous. The breakage/spill problem is not as likely since you won't have that much around. (Unless you bought more than a few ounces from the chem store.) The last note about the acids is to mix properly when adding acid and water. Always pour acid into water, never the other way, and do so slowly, being sure to mix in well. There is a reaction taking place and it releases a lot of energy. During the anodizing process, you will be running electricity through a weak acid solution. This creates hydrogen (just like charging a battery) which is very flammable. This stuff burns at the speed of thought when ignited, so do be careful. (Read as Remember the Hindenburg?) Make certain that there is some way to ventilate the project area, and DO NOT let any sources of ignition near the project area.Other precautions you should take include safety glasses, rubber gloves, and maybe some sort of drop sheet under the area.
Preparations:
One of the most essential things you need to do in order to get even color over the whole part is to be sure that the part is absolutely clean. You want it free of all contaminates, from dirt to the oils in your skin. This is where the nitric acid and some rubber gloves will help. A solution of 1-2 ounces of nitric acid in a gallon of distilled water will allow you to clean the surface in preparation for the anodizing. Aluminum oxidizes very quickly when exposed to air, so the easiest way to keep it clean is to clean it just before you are ready to start working on the piece. (You should rinse the part with distilled water before you put it in the next acid solution.) Other options are carburetor or brakes cleaners, or other similar degreasers. Soap and water will work also, or cleaners like Simple Green. These are cheaper, a nitric acid wash is the best. (You decide, it's your money.)
Make your negative ground with the aluminum wire and foil. Shape the end of the wire into a paddle shape and cover the round part with the foil. What you want to do is create a flat, round shape to sit on the bottom of the bucket, with a lead that comes up out of the bucket. You will clip the battery charger's negative lead to the wire that comes out of the bucket. When you are ready to start, you will want to mix up your immersion solution. In your rubber bucket, combine the sulfuric acid and water to come up with a solution that is about 30% water. (1 part water to 2 parts acid.) Place the paddle in the bucket and attach the negative lead. Then attach the positive lead to the part, making it an anode, and immerse it in the solution. (Remember that the two leads the paddle (cathode), and the part (anode) should not touch.) This is the best time to turn on the charger: once the part begins to fizz, leave it in there for about 10-15 minutes. After about this time the part should no longer conduct electricity. (You can also use an ohmmeter to check conductivity, but this is not needed.) Turn off and disconnect everything, and rinse the part in cold water. Don't use hot water! You'll find out why in the next section.
A couple of notes:
I have read some other procedures that say it is important that the copper lead from the charger does not enter the acid solution. The article says nothing about this, and shows a picture with the lead right in there. It may take some trial and error to find out if this is a problem. It wouldn't be a bad idea to get some scrap aluminum and play with it before you start anodizing your parts. You can check out the above, as well as pick the colors you like best. If you test out some colors, you'll also learn just how long or short you need to work with the color solution.
Color:
So now it doesn't conduct electricity, and is ready for color. It's been rinsed and waits eagerly to change to a new look. Don't wait too long to do the color, due to that oxidizing thing again. You want to mix up a strong solution of dye and water, in a container that can be heated. The solution needs to be at low heat, such as on the stove, so bread and cake pans work well. Again, you need something that will fit the whole part, but it's okay if it touches the bottom this time. I would recommend turning parts every few minutes just to make sure that you get all-over color. Inform your mom or wife that the pan can (and will be) washed out. It is important that the heat be low enough. If the solution gets too hot, you will seal the surface, and it will no longer take any color. (See, told you to rinse it in cold water!) Leave it in the dye until the part is slightly darker than you want it. The next step is to seal the surface of the metal in clean, boiling water. This will leech a bit of color from it, thus the slightly darker color in the previous step.
It is important to realize that the process described above will yield only one color on your part. At this time, I haven't found out how to do any of the splash type of anodizing. (That's okay though, it looks really ugly anyways.) Should anyone happen to figure it out, I suggest you submit it to Warpig so they can put it up for others who like it.
Also, this process is for aluminum. I don't know how, or if, it will work on other metals. (I doubt it.) Anodizing only works well on rock metal like bar or sheet stock, as opposed to castings. If it was forged or machined, it should have the density to take color through this process. I figure this shouldn't be too big a problem with the guns, but just thought I should let you know about it.
Something to consider when looking for a charger, is how many amperes it puts out. Without getting into any mumbo-jumbo, anodizing relies on 10 to 40 amperes per square foot. For small brackets and such, this is no problem. The larger parts in a gun however, may need the higher levels of amperes. The other note about part size, has to do with how long you leave it in the solution. Above it said 10-15 minutes, but that is for a smaller part. The larger parts may not only need higher amperes, but more time as well. I would recommend an ohmmeter, but again, I have one already.
So there you have it. Quick, fairly easy, and not too expensive. If you don't have the charger, then your first anodizing session could cost as much as sending your gun out to be done. But, then you can do it again for much less. Or do your buddies stuff. Or talk them into chipping in on a setup for all of you to use. We all know ways to help make things cheaper.
And the stupid statement required to cover myself... If you try this and something gets messed up, or someone gets hurt, you are on your own. Deal with it, you can't blame it on anyone else. "
Old 01-28-2003, 12:57 AM
I found the first guide on a paintball sitebut the guy that wrote it copied it from a car magazine.
Heres another guide
How to build an anodizer:
http://www.mrtitanium.com/anodizer.html
How to us an anodizer:
http://www.mrtitanium.com/anodizing.html
the anodizer in the first guide is the battery charger if you don't wish to build one.
I was also under the impression that anodized aluminum did not conduct electrcity hence it being so popular as a CPU shim.
Ahh I see Hardcoat Anodizing or Type III Anodizing is the one that does not conduct electrcity.
Old 01-28-2003, 01:00 AM
dabigpig's Avatar
dabigpig dabigpig is offline
you sure talk alot for being silentbob good info tho (skimmed over it)
*** AMC Veteran ***
-- ^-_-^
Old 01-28-2003, 11:04 PM
bdebde's Avatar
bdebde bdebde is offline
That's all folks
Caron Fiber would work great, it is just a pan chassis. You can get the stuff, as well as fiberglass sheets, from larger hobby shops for 1/10th scale rc cars. I think I may have a little of the fibeglass sheet laying around, I may have to try a pan chassis. I used to have a 1/10th scale pan car and loved it, a pan bit would be kinda cool.
That's all folks!
Old 01-29-2003, 12:41 AM
Draconious Draconious is offline
Send a message via AIM to Draconious
http://www.plastidip.com
I say dip the chassis in a thin layer of this...
but before doing so solder the antenna right to the aluminum... it will be a super antenna .
Old 01-29-2003, 01:39 PM
Atomic77 Atomic77 is offline
Thanks for posting the tutorial Silentbob. I think a good coat of clear enamel would be the cheapest and simplest way to go.
Old 01-29-2003, 06:07 PM
RC_EVERYTHING's Avatar
RC_EVERYTHING RC_EVERYTHING is offline
I don't think solder will stick to aluminum.You could put a screw in it and hook the wire on it and tighten it down.
MUST GO FASTER!!!!!
Old 01-29-2003, 06:31 PM
mini rc man's Avatar
mini rc man mini rc man is offline
wtf is a pan chassis?
Old 01-30-2003, 12:01 AM
bdebde's Avatar
That's all folks
It is just a flat plate for the chassis, it can be aluminum, carbon fiber, fiberglass or other materials.
That's all folks!
Old 02-01-2003, 12:54 AM
someone please answer question
Old 02-01-2003, 12:55 AM
n/m didnt see taht post was going through very fast
Old 02-15-2003, 11:35 PM
bdebde's Avatar
That's all folks
Here is a pic of one I am working on. It is same size as a Zip Zap, I left it a little extra long to make it easier to work with.
That's all folks!
Old 02-23-2003, 11:44 PM
bdebde's Avatar
That's all folks
Re: custom chassis production has started
Originally posted by ronak26
hey guys i made a few new chassis a pan chassis, an extened chassis, and a SUPER LONG chassis which is 4 inches and im going to have pics up in a week or so when i get my parts 2morra i can finish the pan chassis.
Well, what's the word on the pics Ronak26? I would also like to see your steering ideas.
That's all folks!
Custom X-Mod Chassis for sale with Transmitter enuke55 For Sale/Trade 2 04-10-2004 01:24 AM
Custom chassis brace. an6e1o82 XMODS Mods and Projects 10 11-09-2003 04:01 AM
How to fit custom bodies to your chassis Stridex Bit Char-G / MicroSizers 3 02-22-2003 10:42 PM
custom chassis and custom bit ronak26 Bit Char-G Mods and Projects 1 01-20-2003 05:21 PM
