01-26-2003, 08:13 PM
Just kinda burned you...
My R-Spec is wierd
When I went to my brother's college to race on the carpet, my R-Spec SLOWED DOWN. Even when I lifted it up.
However, when I play it on hard ground, it runs full speed.
Any explanation?
"I won't lose, no matter what, because the prize is a full tank of gas." Takumi
01-27-2003, 12:28 AM
smoove operator
Redfire; this may be a silly question but, did you get the r-spec from Tiny or Bitchar-g motors?
Because as far as I know Bitchar-g motors doesn't make an r-spec.
01-27-2003, 12:41 AM
Help Me!
maybe the static electricity from the carpet is causing the flux capacitor to discomboobulate?
At the bottom.
01-27-2003, 11:59 AM
I think it was because it drains my battery too fast....
I got it from TinyRC.
The static idea thing is a good explanation, BUT I was also playing with my 3.8 RX7 on the same carpet. There was nothing wrong with it when I used it.
01-27-2003, 12:32 PM
Redfire,
It sounds like your R-Spec isn't as strong a it should be. You can send it to me at:
Kyle Clemmons
P.O. Box 244
Brownsville, KY 42210
I'll test it to see what the problem might be, and I'll test a few new motors and find a good strong one to send you as a replacement.
Sorry for the trouble,
Kyle
BITCHAR-GMOTORS.COM
01-27-2003, 02:01 PM
I think I found out whats wrong with it, my battery gets drained too quickly. I will replace it, since i have more than one battery in my stock.
Same thing happened to my 3.8.
NEW QUESTION!!
-If the part where you push the gear in the motor moves in and out, is that bad?
01-27-2003, 02:04 PM
OK! NEVERMIND, MY R-SPEC IS SCREWING UP!! JUST FOUND OUT AFTER I POSTED MY LAST POST.
Sorry for posting multiple posts.
Consider it sent.
01-27-2003, 06:42 PM
DriFt OnLi
yo kyle can i order a r-spec through u?
 DriFT_
01-27-2003, 07:47 PM
takumi_drifto,
I have an agreement with TinyRC that they will be the only retailer of the R-Spec motors, so you'll have to buy it from Tiny.
Kyle
BITCHAR-GMOTORS.COM
01-27-2003, 08:42 PM
DriFt OnLi
alrighty.. ^^
 DriFT_
02-04-2003, 09:11 PM
It has been sent last friday.
Kyle, you should be receiving it soon under the surname "dela Cruz"
Thank you.
02-04-2003, 09:15 PM
Redfire,
I received your R-Spec yesterday and sent your new one out today.
Kyle
BITCHAR-GMOTORS.COM
02-04-2003, 09:41 PM
So, i should receive it around Thursday or Friday correct?
