Old 01-26-2003, 02:56 PM
isk8blind's Avatar
isk8blind isk8blind is offline
isk8element too.
Send a message via Yahoo to isk8blind
ne1 know how to make a 2-3 speed or booster car?
i was wonderin if someone could tell me how to make my MS a 2-3 speed or booster car. i would like some instructions and some pics if possible plz
thanx
tony
Old 01-26-2003, 03:17 PM
dieselboy dieselboy is offline
Send a message via AIM to dieselboy
refer to my earlier post on "3 speed mod here"
http://www.tinyrc.com/forums/showthr...?threadid=7481
It also helps if you do a search before you post.
Old 01-26-2003, 03:20 PM
isk8blind's Avatar
isk8element too.
uhhhhh
i dont speek japenese though
Old 01-26-2003, 03:33 PM
AzNRocket's Avatar
AzNRocket AzNRocket is offline
AzN InvAzN
http://babelfish.altavista.com/
to translate
Celica :
Auto Modellista Set:
OtheR RyDes:
Bensu Bullet Mercedes
Bensu Bullet fOcUs
Old 01-26-2003, 04:23 PM
BabyKiller's Avatar
lol i speak french
ιtait le wonderin si quelqu'un pourrait m'indiquer comment faire ΰ ma MME. des 2 ou 3 voitures de vitesse ou de propulseur que je voudrais quelques instructions et un certain PICS si thanx possible de plz tony
+ (4.8v)
Old 01-26-2003, 06:21 PM
i said that isk8blind becuase through all my searching no one else has done it or has instructions on it. For some reason that page shows up as
" ‚Ε‚ΝƒoƒbƒN‚ͺo—ˆ‚Θ‚’B‚Ε‚ΰM†‚Ν 2‚Β ‚΅‚©‚ΰ”r‘Ό) ‚΅‚©E‚¦‚Θ‚’ "
and obviuosly isn't in japanese so the translator can't translate. Does it show up as actual japanese text for anyone else? If so would it be possible to email me something?
Thanks alot
Old 01-26-2003, 11:34 PM
dohc's Avatar
dohc dohc is offline
TinyRC Hacker
i can get it
honda accord wagon (3 cell ni-Cad mod, z-cars r/c 3.0 motor, shen qi wei chassis)
toyota bb open deck (dual cell 100 mah mod, shen qi wei motor) microsizer
lancer (3 cell mod, 150 MaH)microsizer
subaru wrx (1 cell mod, 3.0 volt li-ion) microsizer
Old 01-27-2003, 10:46 AM
93civicdx's Avatar
93civicdx 93civicdx is offline
C:\WINDOWS\DESKTOP\
Talking here it goes
CELICA [ Triple-speed Custom ]
Notice * strict observance item: If (there are times when it is not protected, release is stopped.
Concerning the damage * loss with this remodelling, in case of what, the Torii does not have responsibility.
Remodel on responsibility of each one. The proper if you remodel, manufacturer guarantee becomes unable to receive.
Remodelling do not sell the body which does.
Do not designate remodelling method as secret. When (being heard in the friend and the like, you teach gently, or introduce this sight.
As for no permission reprinting of contents prohibition.
Electrically in large quantity there is a technical change ti I part, but do not make the air.
Concerning the explanation of the part and the like because it does not explain, inspect with each one.
Equipment of the PIC lighter/writer and the like is necessary. Concerning around there side especially it does not explain.
Considerably, if it is not curious, do not remodel such. & The person who buys the マルチバンドプロポ boost machine is quick, is.
Because such a ones as for the person who makes it will not be, explanation is suitable. We would like to make truly, if is, please inquire with the mail.
[ The back cannot do with the Dual-speed Custom ]. So only two (furthermore exclusions) it can pick up the signal. In order that there somehow is solved, you try uniting the analog circuit..., collapse. It is not settled at all in the cicely mosquito body.
It installs such time and the Messiah of machine control, it is turn of the " PIC micro-computer ". If the smallest package 8pin size, as for the I/O 6 (input exclusive use) you can use 1. If even with this it does from the body of the BitCharG, deca- I, [ like the LED of the Super Light-up Custom ] if it shaves, it probably is the OK.
The て the project which starts in condition is [ the Triple-speed Custom ]. At the beginning although it was intention of two step speed change + back, production extending to the extension, the boost machine was sold. When that happens, two step speed changes the ぁ it is not funny, don't you think?, with the っ lever in three step speed changes.
* Circuit structure First it cuts off, but uniting the circuit to like this, it does not operate. It is necessary to completely grill the program in the PIC. Please think production is unreasonable in the person where this meaning does not understand.
So it is the schematic.
Sign Part name
PIC PIC 12C509A
Q A Npn transistor " B9D "
Q B Pnp transistor " D9D "
C 0.1 Mu F
R A 1.0k Omega
R B 3.3k Omega
R C 100 Omega
R D 5.0 Omega
R E 3.3 Omega
The part where with respect to the right is red is the original basis that way. In regard to explanation, it is easy to understand, the sea urchin it is inserted.
Signal " FORWARD " from the BitCharG basis and " the BACKWARD " because output level is too small, reversing, has made Lo input.
" The B9D " and " the D9D " are not ascertained not yet even some something, but the resistant entering transistor っ ぽ it is very and is. The ま, even what is good, however is, (<- to some extent). Because the fact that you use " the B9D " just is, the chassis which is broken (you received from the colleague) from taking, using, it increases.
The condenser is for power source stability. Voltage falling instantaneously the motor starts, the fact that the PIC resets is prevented.
As for the R D as for the resistance and R E for the Low-speed it is the resistance for the Middle-speed. In each case as for value of resistance after doing test travelling, it decided no degree. We should change with the condition of the motor and the chassis and the gear.
The PIC is the 12C509A of the smallest package. As for explanation concerning the PIC abbreviation. As for the コイツ unless the program is completely grilled, being not to be able to use, please note. Just the part buying, assembling, you cannot use. Because program size is small, it is all right even with the 12C508A. Because it is necessary to shave in order to install in the cicely mosquito body, the 12C509A/JW for development (EP-ROM edition) you cannot use.
Because the smallest drive voltage of the 12C509A is the 3.0V, the 3.0V power source which was pulled out from the BitCharG basis considerably is last. With the 12C509A/JW of development edition there were times when it does not operate well, but when one time edition (it rebakes and failure) is it operated normally. Because is, because with one shot game the mounted * test was repeated in one time edition, 5 12C509A became wasteful....
* Software Specification is as mentioned below. (Combining operation explanation, it increases.
With " advance " button shift rise, with " retreat " button down-shift.
When " retreat " is pushed in stopped state, the back. However if stopped state does not elapse 0.3 seconds or more, it does not accept.
While pushing " the advance " button, it outputs the Top-speed. (With the Low-speed because it cannot depart)
Generally such feeling. It can download the source from here . (Assembler for AKI-PIC programmer)
* Hardware For the intended achievement that " it installs in the cicely mosquito body ", the tip/chip part is used. (Being the case that time was required for the procurement of here and others side...) with entering, being something which is pulled out from the basis of the BitCharG it does the transistor. " The B9D " 4 takes from one basis. Because two you remove from the body for remodelling, if one there is a motor vehicle cassation body, it is enough.
The PIC after completely grilling the program, shaved in thickness about of the 2mm. The GND line shaves the groove on reverse side of the basis, uses the スズメッキ line there and is wired.
Inside " the B9D " of the BitCharG basis, you remove two of forward, divert to the above-mentioned basis. Drawer position of each wiring is as in the right figure.
So, being final is the photograph to the right. Because the PIC is removed several degrees, the basis is dirty, is.
* Completion shape Somehow it has been settled in the cicely mosquito body. Like this what you do not understand whether the っ ち ゃ uninformed being three step speed changes how is, point. Color the cancer/gun meta being feature, is about the っ て. (There is no black body, is, it is self paint)
* Use impression It is difficult, is. Not pushing the button, being accustomed to the feeling that it keeps running, serious. Being to keep advancing selfishly, going to outside radio wave carry-over factor, the stripe operation stops being effective uninformed. And from edge of desk on bottom of basement....
Whether if it made gently two step speed changes and should have solved, at the honest place. However it is separately simple, don't you think?, the software just is corrected, being. But and the PIC12C509A which is done to leave it was attached when and, removal and re-installation of the PIC the above this is repeated, it meaning that the land of the basis dies stopped the bottom. The ま ぁ, with efficiency it has won the boost machine, (expectation) being to be, it will do well and with will do. From now on [ the Dual-speed Custom ] in order to be able to work above, it perseveres and increases.
[ It returns to the BitCharG ] - [ it returns to the top ]
And that's my word and i'm stickin to it.
Old 01-27-2003, 10:50 AM
93civicdx's Avatar
C:\WINDOWS\DESKTOP\
pics
dd
Old 01-27-2003, 10:59 AM
binaryterror's Avatar
Fear the 1's and 0's
heres a better idea...go buy the Auto Modellista or 350Z set they are both complete booster kits.
Also you can get the 4 band controller and a booster car and do it that way.
slot car speed geofroley Bit Char-G Mods and Projects 8 06-11-2003 04:21 PM
How do i make my car go straight. BitZipAddict ZipZaps 12 06-06-2003 08:28 AM
3.2 motor for booster car good or bad?? microsizer02 Bit Char-G / MicroSizers 3 09-12-2002 11:56 PM
