Old 01-23-2003, 04:55 PM
ZipZapsRule ZipZapsRule is offline
How do u make a muffler right a home?
How do i make a muffler without of going out of my house?
Old 01-23-2003, 05:00 PM
sessiz10's Avatar
sessiz10 sessiz10 is offline
Told ya.
Take a tip of a clicker pen (the ones you have to click ) remove it from the ink tube and there you go. If you want more info please do a search for mufflers or exhaust, the info is here in these threads.
____________________
Meh.
Old 01-24-2003, 12:31 AM
dozzn dozzn is offline
exhaust
I used an asmtha inhaler,,," primatene mist " .... it has that little crome peice on the end of it so it can spray...
I just used some pliers to pull that crome peice out and then used a dremel to cut it my desired length ..... it looks good crome and it also fits the size ratio of the car so it dont look to big,,,
it works perfect... cause has a little tip on it,,, makes it look like a Monza tip.
celica -
Old 02-08-2003, 04:04 PM
AZ_Legend's Avatar
AZ_Legend AZ_Legend is offline
I used the tip of a pen for my exhaust!
Old 01-20-2004, 03:29 AM
needle for pumping up a basketball
the needle for pumping up a basketball works well too. u can get them in packs of 3 or something, i dont rememeber really,
but 1 needle could be used for 2 or 3 cars probably
celica -
Old 01-23-2004, 03:23 PM
nitrousmaniac nitrousmaniac is offline
D1 Grand Prix
i heard that "import tuner" has some nice exhaust
Old 01-23-2004, 06:15 PM
wekilledbambi03 wekilledbambi03 is offline
you can cut the top off a tech teck skate tool and use it.mini tech decks work best.
Home made disc-damper "Black Fiberglass?" Marcro Kyosho dNaNo Parts and Hop-Ups 6 07-22-2008 05:12 PM
can you make home made breitenbach14 Micro-T General 0 01-23-2008 12:41 AM
Make your own composite sheets. bizzybody Bit Char-G Mods and Projects 0 04-05-2007 05:15 AM
how do you make a muffler? AxcZZ ZipZaps 23 01-09-2003 07:46 PM
