Go Back   TinyRC.com > 1/64 and Smaller > Digi Q > Digi Q
Old 12-13-2002, 02:29 AM
rpm3j rpm3j is offline
Digi-Q R Question
Has anyone confirmed if the wheels on the AE86 and RX-7 on the Digi-Q "R" actually turn, or if they are just loose. Does anyone actually have one of these, so I could get some idea how they perform? Also, the new "R" models come in slow, medium, and fast. Is this from different motors or gearing, or just different programming that might be adjusted with a Digi-propo special? Thank you.
-m
Old 12-13-2002, 07:35 PM
GTR's Avatar
GTR GTR is offline
Bravely Runs Away Away!!
it just flops around
Old 01-20-2003, 09:01 PM
sengming sengming is offline
yeah i have one..it flops around ..it still turns but not manually.but their is a suspension just like th bit cahr g
Old 01-21-2003, 05:59 PM
gertman's Avatar
gertman gertman is offline
So...........
Does this make it work better than regular Digi Q???
-Engineering Manager
Old 01-22-2003, 03:42 AM
keal
I'm eager to learn all the details about the racing wheels too!
Old 01-22-2003, 10:33 AM
OKDigiQ OKDigiQ is offline
Yes it does make a huge difference in handling. My Trueno handles so much better than my skyline. I'm sure everyone wants to know if the axles are swappable (is that a word?). I have swapped the straight axle from my skyline into the Trueno, it fits perfect, but the handling was terrible. It made it spin out at a touch of the wheel. I would say that it is much better than a standard DigiQ.
My next test will be to swap the axle from my Trueno into the Pitwork-Skyline I should get in the mail today. Don't know if it will fit but I'm gonna try. I don't see shy it wouldn't based on the swapping I did with the regular Skyline, but I don't want this to be misleading. I'll let everyone know the results.
Steve P
Toys: Skyline GTR, AE86 Trueno, Pitwork Skyline, Honda NSX-R, Jordan Honda CR250(my other hobby)
Old 01-22-2003, 11:34 AM
kwikbb's Avatar
kwikbb kwikbb is offline
smoove operator
OKDigiQ, Great info! Thanks for the comparison... keep us updated on the Trueno axel/wheels ---> Pitworks mod, sounds like a cool fusion.
And Welcome to TinyRC!
Old 01-22-2003, 03:52 PM
keal
OKDigiQ,
Thanks for the great info! Boy, if you can fit those racing wheels
into the Pitworks, that would be so awesome! I will cross my
fingers and toes and pray that it can be done
Old 01-23-2003, 08:56 AM
No problem, glad to help.
You can uncross you fingers and toes, and stop praying.
It works perfect!!!! The front portion of the chassis where the axle fits is identical on both cars. All I have to do now is swap out the rear wheels so the color matches and life will be wonderful!
Steve P
Old 01-23-2003, 09:43 AM
does your pit skyline come with lights?
will this mod work on teh nsx?
i have a ae86 but i really want teh light feature also.
thanks
Old 01-23-2003, 10:44 AM
Yes the Pit Skyline has the lights, it appears to be the exact same chassis as the NSX-R. I didn't look for numbers or anything but physically they look identical.
Yes it will also work on the NXS-R, I just popped the body off of it and it also has the same chassis "connection" for the front axle.
Steve P
Old 01-23-2003, 11:33 AM
can you give me instructions on how to take off the body?
i have teh ae86 so there's no screw..but i'm afraid of braakin it.
thanks
Old 01-23-2003, 11:56 AM
It just pops off. I usually hold the car by the front wheels and pull the front of the body off first, then pull the body off. You shouldn't have to use too much force. Kind off push with your finger on the front off the body forward then up. Hope this helps, it's kind of hard to explain.
Steve P
Old 01-23-2003, 12:10 PM
thanks.
i have 1 q's: can i swap teh turnings wheels fromt eh ae86 to any older digi q ex. wrx, rsx etc.
thanks
Old 01-23-2003, 05:18 PM
keal
OKDigiQ,
Thanks for doing the surgery, that is such good news!
I'm really looking forward to getting the Trueno so I can
play with some wheel swapping
Digi Q Special Settings Jtskty Digi Q 1 10-17-2004 09:34 PM
Digi Q R vs. Digi Q bvsciguy Digi Q 1 09-13-2003 11:25 AM
question about digiq 350z-zz Digi Q 1 04-30-2003 05:49 PM
Combat Digi and ToyEast Question MicroVader Combat Digi Q 1 10-05-2002 09:51 PM
