01-21-2003, 05:04 PM
Anti-Snap antenna Mod
Have you ever extended your stock antenna to come straight out of the back instead of wrapping around the circuit board (PVC or PCV or whatever. Sorry, I'm new), and since you didn't have the anti-snap knot holding it in, had it snap off with a weak pull?? Well have I got a simple mod for you! Just run the antenna straight out the back, and run it through one of the holes on the heatsink. I did this on mine, and I bravely(stupidly) pulled it pretty hard, and it stayed in! Let me know how this works out for you guys!
...but if you REALLY want to earn your spots, you have to face that leopard that lives up on Rice Krispy Hill. I try to, but he always pushes me down the hill, and all of the tadpoles laugh at me!
01-21-2003, 05:09 PM
i usually loosly coil mine and tape it to the heat sink so its not resting above the pcb(interference). im telling you they handle a lot better without that weight sticking out.
01-21-2003, 05:12 PM
When I installed my solid core antenna I:
A) Installed it in the original PCB hole
B) Routed the wire out the back, but then took it up and around the wire clip built into the PCB cover before taking it up and out.
C) Stopped picking my car up by the antenna
No problems so far.
01-21-2003, 05:20 PM
custom title
hehe, i have picked my car up by the antenna. i push my luck by spinning it around
current parts:
auto modellista
4.2 pro
perfection 200mah battery
Pullback wheel mod
Plantraco desktop rover for sale
email me at eman54@optonline.net if you want it
01-22-2003, 08:57 PM
GJ hogjowlz. I didn't know that the antenna above the PCB could cause interference. I'll have to try that.
