Old 01-19-2003, 08:46 AM
ag04 ag04 is offline
Send a message via AIM to ag04
need opinions on absurd idea
The motor on the minix has a long shaft on it, and when replaced, with a different motor, makes it 2 wheel drive. Why couldn't you just wire two motors into the chassis connected to the same power supply? if voltage is a problem, you could use a bunch of li-ion cells (but that's expensive). I it were possible to graph a second motor in, then you could have room for more batteries, and the motors could be switched and exchanged to suit power needs say like a 50 front, 50 back or 20:80 etc. I can't see why it wouldn't work? larger 4wheel drive trucks such as the emaxx, and similar use 2 motors. Why can't a mini x apply the same principals. tell me what you guys think
ag04
Old 01-19-2003, 08:52 AM
binaryterror's Avatar
Fear the 1's and 0's
youd need a big ESC to handle it. Also the 20:80 wouldnt work, because you have to have the diffs going at the same speed or have a 1 way diff in the front or the 2 motors will be fighting each other.
Old 01-19-2003, 09:23 AM
ok, it was only an idea. thanks for the info, I don't have a mini x but am looking into them. but having say 2 micro modified rs4 motors in it woulds give that sucker some kick, especially with 7.2v of power in them.
ag04
Old 01-19-2003, 09:53 AM
ummm just fitting the micro rs4 mods in there would make it kick.
right now the X has a 70T 130 motor. i have been seeing alot of people making the 180's fit though!
I am working on a custom chassis to try this on.
Old 01-19-2003, 10:39 AM
I have another idea, maybe a belts system similar to the mrs4 could be devised. what about a turbo system like in the mini z? maybe stacks and stacks of FETs, or you could re-wined the motor? I got a mini modified motor in my DRR and 7.2v pack, and it goes a merry 20-23mph. Maybe you could make a pan car chassis for the mini x so i could have room for better stuff? like a DRR with minix guts. tell me if it works you guys.
ag04
Old 01-19-2003, 11:08 AM
My plans are to make a dual plane chassis similar to the RS4 so i can put the electronics up top and the batteries down low.
I am still designing the parts in AutoCad and some time next week i should have my calls into the plastics guy and getting some PETG, unless someone can help me find carbon fiber panels, and what to cut CF with.
Old 01-20-2003, 12:20 PM
avenan avenan is offline
I'm no materials expert, but wouldn't PETG in a suitable thickness be fairly flexible? And why PETG as versus fiberglass? I'm a big fan of Garolite g-10 and g-11. Good strength and stiffness. Cheap, available in a variety of colors, and cheap. Less than $10 for a 12"x12" sheet. And certainly light enough.
You can cut CF with a hacksaw, dremel cutoff tool, table saw, jig saw, razor saw...standard cutting tools. Same with fiberglass. I use a combination of razor, hack, and scroll saws, with a dremel for final polishing.
Old 01-20-2003, 01:08 PM
Here's why i want PETG. It is as strong in 1/8" as the garolite. You can easily machine it. It is bulletproof (just under polycarbonate) and you can get it in neat flourescent colors. Also a good reason for PETG/plastic...can you bend fiberglass or garolite? My current design utilizes bending the PETG to form side (also increasing the strength).
I have samples of Garolite coming in, but i currently have better access to the PETG.
I will compare the garolite to my PETG when it arrives and do a break down, who knows maybe my design will have to be totally redone for the garolite.
Also anyone who has bare chassis pictures of the DRR or the DTM SP/X4 would be very nice to have!
Old 01-20-2003, 10:12 PM
Here ya go. A little off topic, but thats ok.
DRR Chassis pics
Old 01-20-2003, 11:23 PM
tinyrc's Avatar
tinyrc tinyrc is offline
Whoa, looking forward to seeing this!
nitrous idea bengali548 XMODS Parts and Hop-Ups 6 07-20-2006 01:00 AM
Is building a motor out of parts a good idea? Bash_N_Thrash XMODS 4 01-26-2004 01:54 PM
What do you think about this track idea? sneuburg Bit Char-G / MicroSizers 1 09-08-2002 05:30 AM
