01-15-2003, 01:43 PM
anyone try hitting the boost during the turn? it helps in getting the rear loose
01-17-2003, 08:33 AM
Tiny RC Pro
01-17-2003, 08:14 PM
AzN InvAzN
i tried doing the boosting during a turn it helps, but sometimes i just spin out.
01-18-2003, 03:52 AM
yeah Bit Char-gs are not as consistent as 1/10 4wd cars. These tiny rcs are harder to drift cuz of the lack of differenctials and none proportional steering.
01-19-2003, 02:29 AM
cool
it would be realy cool to just take the tires off like i did and just us it cuz theres no grip so u can slide all over the fricckin place
its realy fun like that
01-19-2003, 03:17 AM
Help Me!
True dat! I took em all off and just went buck wild! Victory circles! Throw in some baby powder, or graphite lube,that stuff is awesome!
At the bottom.
01-20-2003, 04:29 PM
Go
lol,mine are 2.2 moter drift gears no rear tires its so fun it will do a little wheel spin just in the middle of the track
________
DRUG TESTING KIT
________
DEPAKOTE SIDE EFFECT
________
LIVE SEX WEBSHOWS
01-22-2003, 12:23 AM
lol its amazing how much you can do with an import tuner car.. i made a rear axle with the wheels and the tires and it works so perfect for drifting! when you're drifting around you don't spin around much en yea.. haha well das it
01-22-2003, 09:18 AM
Clones Are Good
Originally posted by cowfish_29
front tires: bit racer hard
back tires: bit racer soft (medium on TheFanMan's track)
softest stablizer bar
blue acceleration gearing
bensu 3.0
Hey cowfish,
What color is the cap on your Bensu 3.0?
My Bensu motor is white, and fast as he!!, but with the right gearing, my 2.2 can nearly keep up.
Also, I get 25 - 30 ft range with my Bensu.
Drift setup:
Bensu motor
Medium front tires
Hard back tires
Soft stabius
7:1 Gears (8 tooth Bensu pinion with 9.6:1 axle/spur)
It just spins donuts with the body, but without the body I can sometimes get it to powerslide on the dining room table.
01-22-2003, 08:56 PM
AA member
a great mod for drifting is to do front wheel drive and rear wheel stearing. just reverse the body of the car. you also have to reverse every thing on the pcb. so just swich forwards and with backwards and left with rite. it looks kool. i did it to my car. remeber to reverse the car when charging
01-22-2003, 09:06 PM
Clones Are Good
Kind of like a Forklift. Interesting...
01-23-2003, 12:24 AM
yellow fish forever!
Originally posted by BenCloned
Hey cowfish,
Drift setup:
Bensu motor
Medium front tires
Hard back tires
Soft stabius
my cap is yellow and looks just like a 2.2 but it ran like faster than my 3.0 and had 4x the acceleration it seemed like. But now its dead, cant decide why. one day it up and quit going fast. It might have something to do with my rally track.
my bensu got 2" of range, and you cant drive with the antenna touching the other antenna the whole time. I just use mine for parts now.
the reason you are donuting is cuz you need softer tires on the back to make your back not slide out TOO much. just enough. Its tricky, so try some different combos with stabiuses and motors (i find that 2.6 tomys are good for hardwood) and just try it out.
01-23-2003, 08:59 AM
Clones Are Good
01-24-2003, 03:18 AM
the best drifting so cheap and fun
y dont u just take tires off all wheels and go all over the place its realy fun or if u dont feel like buying drift gear than just take back tires off simple as that
01-24-2003, 09:42 AM
Clones Are Good
Most of us still want control over the car. It's a racing technique.
